San Diego Area Alignment Shop - Results
Before and after data for alignment done by:
Dan's Precision Alignment
565 Westlake St # 200F
Encinitas, CA 92024-3763
(760) 753-0481
Dan knows the 928 and has the newer Hunter machine so the car is never lifted.
Much improved steering and tracking.
(760) 753-0481
Team Owner
you could fix the rears Camber by swapping in new upper control arm bushings on the dog bones,
and or also adding new lower control arm bushings
where the LCA attaches to the rear cross member
$150 - took 1.5 hours. Just hang out in the shop while he does it.
Under the Lift
Why did he make the front caster, initially right on the money, grossly unequal? Honestly, the initial aligment was only off much in rear toe. Front toe was essentially zero, which usually drives pretty well.
Why did the rear camber increase from the initial alignment? All he should have touched in the rear is the toe adjusters and that should not effect camber.
Frankly, I wouldn't have been too thrilled with the results.
Cottage Industry Sponsor
Perhaps the question should be: How many Bloody Marys did he have while the alignment was done...?
Randy,
When you say the handling is "much better" one would think it might be "less twitchy" given the front toe setting before. Is that what you experienced or some other perception of improvement?
I would not have accpeted that difference in caster plus or minus 0.1 is what I look for at or around 5 degrees. I understand Porsche recommend 5 degrees of caster on later model specs but this is equally applicable on earlier [32V] models- the computers on alignment machines will show 4 degrees for earlier models but for your GTS I would have thought it would indicate 5 degrees as the target.
Best wishes
Fred
Best wishes
Fred
Your mother wears Army boots.
I neglected to mention that Dan does a free re-check after 1000 miles. We'll get it all dialed in then.
Randy,
Best wishes
Fred
Best wishes
Fred
I guess I could have read the thread more carefully and found that out rather than calling him. It was interesting though because he said he didn't like to do them and he really likes to get paid. I took that to mean that he charges more than usual for the 928s than perhaps other cars.
Jerry Feather
Jerry Feather
Rennlist Sponsor
Bill,
Yes he is, but it is a GOOD Kind of Strange,....he fits right in with the rest of us!
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Randy,
If you find you need new bushings for the dog bones as Stan suggested, I got you covered. Just let us know and they are yours.
Randy,
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
Former Sponsor
As the bushings in these cars wear, sometimes you have to choose between the "proper" rear camber or the "proper" rear toe. Obviously, this shop thought that the proper toe was more important than a little bit more camber....and they are probably right.
