928 Forum 1978-1995
Sponsored by: 928 Specialists
The build a 928 boat thread.
Old 08-08-2011, 01:26 PM
  #151
Tass 928
Tass 928's Avatar
Sunday was to wet to do the outdoor welding so I worked on the hull again. I used some very carefully applied paint stripper to remove the dragon mural on the passenger side. That left me with a shadow outline of the dragon that could still be seen in certain light conditions. I hit it with 600 wet paper and most of the shadow was cleaned up.
Old 08-08-2011, 01:34 PM
  #152
Tass 928
Tass 928's Avatar
I decided to take a shot at wet sanding and buffing a section to see if I could save the original finish of the boat. I spent a few hours doing the top right side and the result was "not bad". I could see spots where the compound did not cut the sanding marks and I would need to use some finer paper before buffing. I can see this working, but I'm not fully convinced I'll be happy with the end result. I decide to hold up and talk to a professional.
Here are a couple pics of how I left it. Better....but not there yet.
Old 08-08-2011, 02:00 PM
  #153
Tass 928
Tass 928's Avatar
This morning I stopped in to see fellow 928'r and body man, Walter Black. While I was complaining about my mediocre buffing results, he collected up some wet paper, a polisher, and some squirt bottles of compound and said "lets go take a look". He hit a rough section with 600 paper then 1200, following up with a wool buff loaded with compound. The results were unbeleivable....it was super shiney before he even hit it with the swirl mark remover.
So the lesson learned is that I suck at buffing and more importantly, I won't have to do a costly repaint of the entire boat. There are a few gelcoat nicks that Walter will fix for me (he is also the guy that molded the glass dashes for me) and then I'll be accepting his offer to sand and buff the boat. With the exterior finish question resolved, I'll go back to working on the mechanicals. Next up will be motor mounts.
Here is a pictures of Walt's test area......After this, I'll bring my camera home and stop putting up crappy I Phone pics.
Old 08-09-2011, 03:03 AM
  #154
docmirror
Shameful Thread Killer
docmirror's Avatar
Yummy. I wet sanded and buffed a 16' Schiada long ago. It was a hell of a job but came out like that. Doing the bottom is a chore, but you don't see that part much.
Geez, James did you have to bring up the PFM? What a monumental screw up that was. Almost put two companies out of business. Cost Porsche it's CEO, and sent Mooney spinning for years.
Old 08-09-2011, 11:01 AM
  #155
James Bailey
James Bailey's Avatar
Sorry but I saw one at a POC event at Firebird Raceway in Phoenix when it was a new plane. They landed it on the drag strip portion of the road course. It was odd to see a "911" engine in a plane and gear reduction drive just seemed wrong...
Old 08-18-2011, 03:19 PM
  #156
U-928
U-928's Avatar
Progress?
Old 08-18-2011, 03:55 PM
  #157
Tass 928
Tass 928's Avatar
I was out there working on it but the progress I made is not anything picture worthy. My goal was to get the engine supported in the correct position so I could make motormount templates and then fab up the mounts this week. When I got the engine where I needed it, we had two contact situations. One was the starter hitting the side of the engine well and the other was my bell housing hitting the jet pump mounting bolts. I had the engine in and out five or six times while I trimmed the pump bolts and then finally had to trim a little off the bell housing itself. The starter issue was solved by simply rotating it 180 degrees.
I'm ready to put the engine back in and I know the angles and position I am looking for. Hopefully I'll make the mounts next week.
Also some trailer progress: I welded in the backing plates on the fenders, refit them on the trailer and then drilled the mounting holes. I picked them up from the blaster today and dropped them with powder coater. My phone dials were hanging in the booth when I got there and he was going to try and run the fenders at the same time.
I'm working on a slide-out extension idea for the back off the trailer that will protect the jet drive from light impact and stray pedestrians. It will also help me when backing into the garage. The rudder fin is pretty fragile and it looks like the PO had to have it welded once already.
Old 08-18-2011, 04:34 PM
  #158
DR
Rennlist Sponsor
DR's Avatar
Originally Posted by U-928
Progress?
Yes Dave more progress, patiently waiting for ya......
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 08-18-2011, 04:49 PM
  #159
DR
Rennlist Sponsor
DR's Avatar
Commonly done for Race Boats (see below), although not removable since they are hoisted off the trailers....but easy enough to make a slip in frame held in place with snap pins for easy removal...think of the removable legs on an engine hoist, except with quick pins instead of "pinch bolts".
Old 08-18-2011, 04:52 PM
  #160
Tass 928
Tass 928's Avatar
Oh thanks...your taunting me now
I'll take that as motivational
Old 08-18-2011, 04:53 PM
  #161
James Bailey
No surprise given the cost of those props and the racing lower units !!!!
Old 08-18-2011, 04:57 PM
  #162
Tass 928
Tass 928's Avatar
Oh hey.....whats the name on the side of that boat...."r"-something...
Racer?
Terror?
Trouble maker?
Just wonderin...
Old 08-18-2011, 04:59 PM
  #163
Tass 928
Tass 928's Avatar
Yes..like that ! I guess I didn't have an original thought but at least it was a good one.
Thanks for the pic..
Old 08-18-2011, 05:57 PM
  #164
DR
Rennlist Sponsor
DR's Avatar
Racer?
Terror?
Trouble maker?
Just wonderin...
This Offshore Racing Hall of Fame Nominee knows...he named it, race rigged it and raced it to a string of APBA/NPBA A-Class wins in the 80s/90s... :-)
Old 08-19-2011, 01:44 PM
  #165
mallman
mallman's Avatar
Really nice old racing boat, won a lot of races. I would like to have what the boat was named after.
Quick Reply: The build a 928 boat thread.
