So what did you do to your 928 Today......
#1456
All the vacuum hoses were unhooked from when I bought my 928. I found a diagram and a few pics and hooked them all up. Center vent works and I had to leave for a party on a boat. I feel goodddddd...
#1457
Addict extrordinare
Disconnected the flex plate and confirmed the noise the car is making is TT and possibly TC bearings. Checked the crankshaft end-play, and it's at 0.22 mm
. Started TT removal process so TT and TC bearings can be replaced (removed exhaust from muffler up to cats). Got rid of this little stowaway gift from a previous owner.
#1458
Repaired driver window motor again-Dremel wire brush vs copper motor pieces. Now it works again albeit slowly going up + relubed moving parts. Also had to resolder motor connection. Fixed power mirror too. Door panel strip down time is like 10 mins now that I know where everything is!
#1459
Thank's to Jeannie and Dave Roberts, now will have to make a space for this one. Track car or toy for the road ?
#1460
Cruised around on the highway. Went 140....................kmph. Went to my Buds place a ways away.- Not home !
Saw some slutty types staring. That is all.
-Oh yea- put in regular !!!!
#1461
Started tearing apart my engine to put in new head gaskets, timing belt, porkensioner, water pump, thermostat, big gasket thingy. Engine hydrolocked on me one day.
![Name: photo-3.JPG
Size: 44.7 KB](https://rennlist.com/forums/attachments/928-forum/554947d1311731774-so-what-did-you-do-to-your-928-today-photo-3.jpg)
#1463
Got the TT & 5sp back in my 81. Plan to get the lower bellhousing w/starter etc and exhaust on today.
Weather Channel says 98 today, work til the AC loses its struggle.
#1465
Finished up replacing a seized water pump,new timing belt, new tension roller bushings.....swapped on a new set of Victoracer tires. Saturday and Sunday get to run the Pomona Fairground track
#1466
Yesterday, Mark & Jesse from Glacier Window Tinting in Arlington, TX applied Wincos 30 Automotive Film to my 928. I chose Wincos (Window Cosmetics) for three reasons: the IR Rejection is 92%, UV Rejection is 99% and Solar Energy Absorption or Heat Rejection is 73%. All five windows are the same shade. I was looking for an elegant window tint that keeps out the Texas heat while maintaining the premium look of a 928. The result is my interior is much cooler and I'm not driving around with blacked out windows.
#1470
Got parts from Roger Thursday, and had already taken console, etc all out of car last Tuesday night. Eight o'clock this morning started to take Actuators apart. Had a difficult time getting the Combo rod back on the pin so drilled a hole per Dwayne's write up and popped right in (Thanks!).
Changed out the footwell diaphram, even though it held vacuum but had gotten two diaphrams so decided while I was in there. Then tested everything before putting anything back, and all worked well. Then put all back together. Fixed passenger side window switch per Tony's write up ( thanks!) and rewired the suction fan that pulls in air to inside temp sensor, wires had been cut?? PO??
All buttoned up by Three this afternoon, not too bad of a job.
Started up and temp in garage was 78 degrees and after about 3-4 minutes it was 58 in the car. Ready for vacation and trip up to Owls Head Museum Sunday for car/airplane show. 100 miles to my place in Scarborough, Maine and then another 100 miles to Owls Head...what better way then to start a vacation..
