928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 01-02-2023, 07:04 PM
  #8506
Broccoli
Broccoli's Avatar
Default 1986.5 electrics
I've been restoring my 1986.5 928S, but it got past the point of being "restored" so now I'm posting the process here.
Today I reassembled the fuses & relays.
Weeks back I took all the fuses and relays out, disconnected the connectors and bathed everything in deoxit. I also had the pod out for an odometer gear replacement and re-paint of the spotted instrument cluster backing, so cleaned up the switches, too. I was having some weird issues with the headlights not retracting and the fog lights never worked. Also, when I got the car the connector for the interior lights. So I ordered new "53" fuses because they're cheap, and only new fog light and headlight relays because they're not cheap. Today I filed the fuse contacts clean and checked for continuity, and changed out the new relays. Headlights now work consistently and the fog lights turn off and on. And while fiddling in there, the interior lights kept flicking on and off. The interior light relay was intermittent so I popped it out of the cover and discovered a loose solder. With a fresh bead the relay works consistently now. It's nice to have these original problems solved!
before cleaning and replacing
during cleaning
during cleaning
Sorry - no pic of the new job!
The following 7 users liked this post by Broccoli:
Brent A. (01-04-2023), Gary Knox (01-03-2023), JBT3 (01-02-2023), JJ928S4 (01-03-2023), RennHarry (01-19-2023), Sagres74 (03-26-2023), voskian (01-22-2023) and 2 others liked this post. (Show less...)
Old 01-17-2023, 02:30 AM
  #8507
Michael Benno
Michael Benno's Avatar
Default Painted rear wing
After months of waiting, the wing retuned from the painter color matched to the body as it was from the factory. Thanks @Rob Edwards for the hookup!
The following 7 users liked this post by Michael Benno:
928 GT R (01-22-2023), 9two8 (01-17-2023), chassis (01-22-2023), RennHarry (01-19-2023), Sagres74 (03-26-2023), Slavic (01-17-2023), WestInc (03-09-2023) and 2 others liked this post. (Show less...)
Old 01-19-2023, 01:59 PM
  #8508
Darklands
Darklands's Avatar
Received 1,148 Likes on 619 Posts
So, I decided to build modern looking wiper Arms. First I Cut them.
You need a big Hammer to loose the wiper holder.
Epoxy glue
I use epoxy glue, because wielding makes corrosion.
Rust from heat
928 GT R (03-09-2023)
Old 01-19-2023, 02:15 PM
  #8509
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Epoxy glue
Rust from heat
Not following what ya did here?
And dirty welding makes corrosion..
Old 01-19-2023, 02:23 PM
  #8510
Darklands
Darklands's Avatar
Tomorrow I can make new photos in my barn!
The new arm is fitted together with three pressure marks on each side!
9two8 (01-19-2023)
Old 01-20-2023, 01:12 PM
  #8511
Darklands
Darklands's Avatar
My problem with the Aero wipers on the original arms is at high speed they loose contact to the windshield.
For people who know to hold a hammer this task is a 2 - 3 hour job and the look is way better!
Complete cost for the job are ~ 150 € incl. Aero blades.
Old 01-21-2023, 09:39 AM
  #8512
Darklands
Darklands's Avatar
Changing the alternator Tube and the Belly pan. New injectors and damper are in and pressure is OK.
NExt step is the regulators.
I m pleased all parts are retour.
Old 01-21-2023, 11:41 PM
  #8513
AFRyan79
2nd Gear
AFRyan79's Avatar
Great looking ride! I have an 86' just north of you in OKC. Great rides for sure!
The following 2 users liked this post by AFRyan79:
928 GT R (03-09-2023), Darklands (01-22-2023)
Old 01-22-2023, 01:57 AM
  #8514
v8_ranch
v8_ranch's Avatar
Completed installation of the GM alternator this morning and then drove it to cars n coffee
The following 4 users liked this post by v8_ranch:
928 GT R (03-09-2023), 928NOOBIE (03-01-2023), 9two8 (01-22-2023), WestInc (03-09-2023)
Old 01-23-2023, 07:13 PM
  #8515
WestInc
WestInc's Avatar
Handbrake refurb and clean. The button was sticky as hell. No wonder, the small cracked polyurethane bushing was inbetween the handle and spring. Some coins had been under the handle for quite some time I think... 1 Pfennig from 1950..
Old 02-19-2023, 07:53 PM
  #8516
928NOOBIE
928NOOBIE's Avatar
Went for a 100 mile highway run after installing this:
Custom FPR from Greg Brown
A great upgrade. Had a stock '87 year FPR about 10-12 years old in it. More power, noticeably smoother engine at all rpm, more part throttle power and smoother application of power. Noticeably more punch in 5th at 70 when tipping in. Torque torque torque. Many smiles. Now adjusting MAF Ohms to find the new happy place.
Also recently: new set of custom Beru wires courtesy of Roger at 928sRus and upgrade to NGK BP7ES non-resistor plugs; custom gapped to 0.9mm per Ken's recommendation. All together making a very nice difference.
The following 2 users liked this post by 928NOOBIE:
928 GT R (03-09-2023), JBT3 (02-19-2023)
Old 02-28-2023, 06:57 AM
  #8517
Tops2808
Tops2808's Avatar
New instrument cluster foil.
Old one...
New one...
The following 2 users liked this post by Tops2808:
928 GT R (03-09-2023), Gary Knox (02-28-2023)
Old 03-09-2023, 05:48 PM
  #8518
WestInc
WestInc's Avatar
Finished refurb on my ebay-headlight from italy today. The paint didn't match the original grey/beige colour on the reflector but I think it went ok anyway. Gave the silicone-seal a fine scrub and a new toplayer seal. Did also save the original sticker..
Dissasembly... Surface-rust, but nothing through the seal or inside the reflector.
Nice and shiny...
The car came with a newer headlight on the right side as the left picture shows. But now, no more "blue" and "brown" eyes. Hard to see in the pictures but a very noticable apperance IRL...
It can of course be exotic on a nice husky! But it doesn't fit our nice Porsche's...
The following 5 users liked this post by WestInc:
928 GT R (03-09-2023), Bertrand Daoust (03-10-2023), G.P. (03-10-2023), JBT3 (03-09-2023), zaevor2000 (03-09-2023)
Old 03-09-2023, 11:07 PM
  #8519
928 GT R
928 GT R's Avatar
Received 5,296 Likes on 2,039 Posts
After a long day of not playing with my 928's I just stopped by to look at them... enjoy the sheer beauty...
The following 4 users liked this post by 928 GT R:
Bertrand Daoust (03-10-2023), Darklands (03-21-2023), dimi5928 (03-20-2023), RennHarry (03-20-2023)
Old 03-09-2023, 11:55 PM
  #8520
zaevor2000
zaevor2000's Avatar
Very nice!
I also like the sitting area off to the side.
Fantastic what you have accomplished there.
Always great to see a vision become reality.
Would love to see this one day in person.
The following 2 users liked this post by zaevor2000:
928 GT R (03-15-2023), Bertrand Daoust (03-10-2023)
Quick Reply: So what did you do to your 928 Today......
