928 Forum 1978-1995
Sponsored by: 928 Specialists
In need of a S4 transmission
Old 02-01-2011, 12:48 PM
  #31
mark kibort
mark kibort's Avatar
dont worry, you dont think that was my FIRST call?
Originally Posted by BC
Old 02-01-2011, 12:50 PM
  #32
mark kibort
Lets bring cherboreator's S4 2.64 gear box in from europe, and Ill trade you.
thoughts?
mk
Originally Posted by Andre Hedrick
Find me a rebuilt G28/10 through G28/12 with LSD and I will give up my G28/13 with LSD. It took me 3+ years to fined this and I am not really wanting to give it up; however, if you get the 5-speed with the 2.64 gear with LSD preferred, I would gladly trade!
Old 02-01-2011, 12:53 PM
  #33
mark kibort
I might take you up on this, if Andre' cant pull off a trade with me and Cherberators S4 box.
Thanks. Looks like Im getting close!
much appreciated guys, because as it stands now, all racing is on hold!
mk
Originally Posted by FBIII
I have Randy Faunce's Devek rebuilt 2.20 with LSD I'd sell for $2700. The only reason I'm selling is to fund the proper GT transmission for my car.
Old 02-01-2011, 01:36 PM
  #34
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by mark kibort
why does does my garage smell like gear oil? there are no leaks, but that rubber plug has been removed to see if the torque tube shaft broke or the end of 5th gear.
There has to be a hole somewhere in the transmission or the oil must have leaked out for you to be able to smell it. Gear oil has a very strong smell, it doesn't take much to stink up a garage.
Old 02-01-2011, 01:44 PM
  #35
mark kibort
sure, the cover (plug) is off the rear, but there was a little oil back there. but very discolored, probably from year of not being touched and some pretty high temps. probably just seepage. with the plug out, this slight leakage, must be the sourse of the smell. or , durign the failure, something happened in the trannie for it to burn up .
I have a suspision that the gear didnt loose teeth, the shaft broke inside. but I wont know until I get it out. either way, its coming out, so that is the next step.
Old 02-01-2011, 02:50 PM
  #36
Andre Hedrick
Rest in Peace
Andre Hedrick's Avatar
thoughts?
mk
When you get the box from Europe here, bring it by the house and I will put the car up in the air and remove my G28/13 w/ LSD. Does Cherboreator's box have a LSD also?
Old 02-01-2011, 04:50 PM
  #37
IcemanG17
IcemanG17's Avatar
mk
Or you could get your NASA license and race the Estate in GTS2....probably win too...then you win FREE Hoosiers through the contingency plan!!!
Old 02-01-2011, 05:45 PM
  #38
Mike LaBranche
Mike LaBranche's Avatar
How far off are the dimensions on the early 5 speeds from the S4's? Any chance of making an earlier box work?
At any rate, all speculation is just that until the part is on the bench in pieces. You may end up better off with a fresh part instead of a box.
Old 02-01-2011, 05:54 PM
  #39
namasgt
namasgt's Avatar
Mark
I dont know why no one has sugested this idea yet.
I think you should be the first to convert a 5 speed to an Automatic! There’s plenty of them out there and they seem to be very well built.
Old 02-01-2011, 06:44 PM
  #40
mark kibort
you dont want to race the early boxes, by choice anyway. the S4 box is a dream to drive, but both work. the S4 is much stronger due to bigger stronger gears and much better and durable synchros.
Your right! i have to get it off the car and opened up. im hoping its just a broken 5th gear shaft, not gears without teeth!
Old 02-01-2011, 08:13 PM
  #41
Mike LaBranche
Guess that depends on how bad you want to race...
Old 02-01-2011, 08:28 PM
  #42
The_Remora
The_Remora's Avatar
HOw about selling the busted 5-speed to the guy who's restoring the old Holbert car which would be worth more with matching #'s, put that $ toward working replacement? Just a thought.
Old 02-01-2011, 09:30 PM
  #43
Richard S
Richard S's Avatar
Mark, why not put in that special 928 6-spd transmission you picked up in Mexico a while back?
Rich
Old 02-01-2011, 09:47 PM
  #44
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Was it maee in Mexico too???
Old 02-01-2011, 11:19 PM
  #45
mark kibort
I sold it back to Herr Kunz for his V10 928 engine expansion racer project.
Rich
Quick Reply: In need of a S4 transmission
