928 Forum 1978-1995
Sponsored by: 928 Specialists
early dyno results
Old 03-17-2011, 03:37 PM
  #526
BC
BC's Avatar
If someone doesn't smile with this motor, they're walking dead. CHEAPER THAN THERAPY!!
BC is offline
  #527
Darklands
Darklands's Avatar
Received 1,167 Likes on 630 Posts
Congratulation for this amazing piece of art!
Greg,one question.What do you think about an engine with your modifications but stock 5 l displacement.
Is such an engine also capable to make ~ 100 hp /l displacement crank hp or do you need more stroke for maximum efficency ?
Darklands is offline
Old 03-17-2011, 03:39 PM
  #528
AO
Supercharged
AO's Avatar
Awesome figures.
Stupid power? Not at all.
What was the final displacement? 6.4l?
Can you elaborate as to the areas you needed to modify/change to fix the oiling issues? I understand if you;re not wanting to tell specifics, but maybe generalities? Like, modifications to the oil filler area, cam breathers, additional head work, etc?
I'm happy for both you and Andy. Great job!
AO is offline
Old 03-17-2011, 03:42 PM
  #529
AO
Supercharged
AO's Avatar
Originally Posted by Randy V
So does that mean that Andrew got pwned?
Never said they were the be-all, end-all best header option (although they are one of the better options). I'd love to have Greg's headers, but I think I got a much better value at $450 vs. $1,000+. So no, I did not get pwned.
AO is offline
Old 03-17-2011, 03:44 PM
  #530
Randy V
Randy V's Avatar
Own the pwneage.
Randy V is offline
Old 03-17-2011, 03:46 PM
  #531
AO
Supercharged
AO's Avatar
Own the pwneage.
Cyber-bully!
AO is offline
Old 03-17-2011, 04:47 PM
  #532
Hilton
Hilton's Avatar
Originally Posted by Hacker-Pschorr
Now we're talking!!! Very nice.
A long time ago there were two very similar 928's on the same dyno both doing some tuning with similar (pre-shark tuner) software.
The car with the DEVEK Level 2 headers made more overall and peak power than the car with the "snake" headers.
I would stick with Greg's if I were you.
Interesting - john gill had some snake ones made for his modified GT.
Sound available on his build page here--> http://www.emtec.net.au/928GT_engine.html
Hilton is offline
Old 03-17-2011, 05:16 PM
  #533
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,752 Likes on 1,336 Posts
Greg sent me faxes of data, as his scanner is misbevhaing. I pulled the #'s and did a quick makeshift dyno curve just to have a pciture to look at:
Raw data for Devek L2 headers:
Raw data for Greg's exhaust:
Graph:
Rob Edwards is online now
Old 03-17-2011, 05:40 PM
  #534
jcorenman
jcorenman's Avatar
Originally Posted by GregBBRD
The engine makes over 400 ft lbs from 2,000 to 7,000.
It makes over 450 ft. lbs. from 3,800 to 7,000. ...
Now THAT is sweet!! Well done!!
jcorenman is online now
Old 03-17-2011, 05:57 PM
  #535
jorj7
jorj7's Avatar
Congratulation Greg, good power figures and for solving the oil problems.
If the A/F-l column is Air Fuel Ratio, then I think there's lot's more horsepower left
on the table with Gregg's headers by getting that ratio up to the same/similar levels
as with the Devek headers. But then that would require more tuning that would
probably not used on Andy's car.
jorj7 is offline
Old 03-17-2011, 06:00 PM
  #536
Rob Edwards
Archive Gatekeeper
My guess is that the WBO2 was lying on the ground after Greg installed his headers, since there's no bung in the collectors.
Old 03-17-2011, 06:16 PM
  #537
Rick Carter
Rick Carter's Avatar
I'll start saving money for the oil fix.
Rick Carter is offline
Old 03-17-2011, 06:23 PM
  #538
jorj7
jorj7's Avatar
OK, that would explain some of it. But the WBO2 sensor would have to be laying
next to a puddle of gas or something to get those numbers. But that's beside the
point, this session still shows great numbers and that Greg's headers had higher
power with the same engine and tune.
jorj7 is offline
Old 03-17-2011, 06:24 PM
  #539
IcemanG17
IcemanG17's Avatar
great power with a conservative tune.......plenty rich for safety....especially down low....which is opposite of that the stock LH system does.....normal towards lean in the middle then crazy rich up top....
IcemanG17 is offline
Old 03-17-2011, 06:39 PM
  #540
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
I've found that you have to be very careful with dyno fuel mixtures readings. The engine passes so quickly through those numbers that the readings are not necessarily accurate. Those A/F numbers that are in the 10's and 11's are actually about 12.5-13.0, if you go to those individual cells and hold the power steady.
Same thing happens when I tune on my Mustang Chassis Dyno. I'm able to hold things longer and more accurately tune an "individual point". If we go from the Mustang over to a DynoJet, the dynojet guy will always "freak" out at how far off the mixtures are.
I've found a Dynojet just a bit better than nothing, when it comes to tuning A/F mixtures...nothing has enough time to stabilize, when the engine sweeps so quickly through an RPM range.
GregBBRD is offline
Quick Reply: early dyno results
