928 Forum 1978-1995
Sponsored by: 928 Specialists
Empty shell to finished car
Old Apr 5, 2014 | 11:02 PM
  #316
FLYVMO's Avatar
FLYVMO
Originally Posted by Igordiver
It's not just an amazing job. It's inspiring.
Dank U!
Are you in the french, german or flemish part?
Carl
Old Apr 5, 2014 | 11:09 PM
  #317
FLYVMO's Avatar
FLYVMO
Originally Posted by Captain_Slow
.......Hopefully it isn't the Six Million Dollar 928
I sure hope not...haven't looked at the spreadsheet in a while though...
Cheers!
Carl
Old Apr 6, 2014 | 12:13 AM
  #318
FLYVMO's Avatar
FLYVMO
Originally Posted by Bertrand Daoust
+1.
Superlative job!
A lot of people's dream here I think... Mine at least!
Keep up the beautiful work.
Thank you Bertrand,
Everyone's positive comments and suggestions goes a long way, and I appreciate all of them very much. I'm starting to see the light at the end of the tunnel...
Cheers!
Carl
Old Apr 6, 2014 | 06:24 AM
  #319
Igordiver's Avatar
Igordiver
U speak Dutch
I'm from the Flemish part. Pretty close to the Dutch border.
Old Apr 6, 2014 | 01:12 PM
  #320
FLYVMO's Avatar
FLYVMO
U speak Dutch
Only picked up a few phrases during my many stays in Liege. Very pretty area in the spring and summer.
Cheers!
Carl
Old Apr 6, 2014 | 07:30 PM
  #321
The Fixer's Avatar
The Fixer
This is a TRUE restoration.
Old Apr 6, 2014 | 09:47 PM
  #322
FLYVMO's Avatar
FLYVMO
Let's call is a resto-modification
Your project is looking great Matt! What weight is your car down to now?
Cheers!
Carl
Old Apr 7, 2014 | 09:34 AM
  #323
Igordiver's Avatar
Igordiver
Liege is verry beautifull. The ardennes as a whole infact with probably the greatest circuit in the world, Spa-Francorchamps.
Old Apr 7, 2014 | 08:01 PM
  #324
The Fixer's Avatar
The Fixer
Cheers!
Carl
Carl, thanks.
Your GT is going to have that 'new car smell' though.
I like the mods you've elected to make.
A bond with this car, you will have. (said in a Yoda voice)
May the car Gods smile upon you and your GT.
Old Apr 12, 2014 | 06:19 PM
  #325
FLYVMO's Avatar
FLYVMO
Default ISIS Electrical install begins
Today I started mounting the ISIS system, starting with the CEB "replacement". Previously I made a mounting tray from ABS plastic of close to the same dimensions as the factory CEB. This tray will hold the Mastercell that takes all the inputs from switches and other triggers (left module in picture), and one Powercell that powers everything inside the cabin. Not shown in the pictures is the InMotion controller that handles power windows, power door locks and headlight motor. This controller will be mounted on the side footwell wall where the LH/EZK computers normally mount. Also not shown are the 2 additional Powercells (one front and one rear) that handles all the power loads in those areas. They look exactly the same as the one pictured. The only connection between the cells is a CANBUS type network cable. That really cuts down on the amount of wires running back and forth. The CEB tray also houses the diagnostic plug, which is moved from its normal location near the amplifier.
One of the pictures shows the key FOBs which can control any output that has a control switch or connection to the Mastercell. Each FOB has several "pages" that you can skip to by pushing a function key, so one remote can have 16 different controls.
Security is built-in to the Mastercell and will isolate the starter and sound the horns if doors, trunk or hood is opened while armed. Because there is no typical ignition switch wiring (no battery power going through the switch) trying to hot wire the car while security is enabled will not work.
Each Mastercell has 50 inputs (can be anything, a switch, a signal, a frequency), and each Powercell has 10 outputs, each at 25A max (more if adding a relay), and can also PWM several of the outputs.
I also got the DBW pedal mount done, basically modifying the stock gas pedal mount by drilling two holes for the DBW pedal to mount to. Left to do is to add a support for the left side of the DBW bracket, and get the actuator arm to align properly with the 928 pedal. Dropped it off at the local machine shop to have them modify the actuator arm accordingly.
Hopefully I will have more pictures next week, now I have to go play with an intake someone sent me Tony, there is some cutting to do!
Cheers!
Carl
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 29, 2014 | 05:15 PM
  #326
FLYVMO's Avatar
FLYVMO
Default Ventilation blower upgrade
A few more items accomplished last week. The rear ISIS power cell is now mounted in the drivers rear wheel well, where the PSD usually sits. This unit will control the tail lights, brake lights, rear fog lights, turn signals, backup lights, license plate lights, rear defroster, rear hatch release motor and trunk lighting. I have the interior lighting separated in 2 areas, so when the trunk is opened, only the lights in the trunk area will come on. Opening any passenger door will illuminate all interior lights. Can also be selected from a toggle switch in the dash.
Fuel tank is in place, heat shield upgraded on the rear of the tank cradle, DR's sway bar with new bushings and mounting brackets are installed, along with new brake lines.
Also upgraded the ventilation blower with a new motor. Actually ended up getting motor and squirrel cage, but the fan easily pops off the new motor and the stock fan presses on the new motor. The motor from a 1992 VW Passat is a direct fit, the only thing that needs to be modified is lengthening the power and ground wires, either by splicing or desoldering the connections on the motor and re-soldering longer wires. While I had the motor apart, the fan casing got a fresh coat of plastic paint. That should last another 25 years I hope.
Cheers!
Carl
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 29, 2014 | 05:19 PM
  #327
77tony's Avatar
77tony
Veteran: Army
Hey Carl, I'm sure you won't butcher that intake as seen in the work performed so far. Slick install on that rear mounted ISIS cell T
Old Apr 29, 2014 | 05:26 PM
  #328
FLYVMO's Avatar
FLYVMO
Thanks Tony!
I guess this means it is no longer a 928 because I have a non-original ventilation blower fan installed....not to mention non-stock electrical system..oh the horror
JP is looking great after the alignment. What's next? Hey, you said I could cut it....hehe. Haven't modified it yet, but it should work. Will work on it when I get back. Check this one out too: http://www.airaid.com/ProductDetail....ductID=250-230
Carl
Old Apr 29, 2014 | 05:29 PM
  #329
77tony's Avatar
77tony
Veteran: Army
Thanks Tony!
Carl
Waiting on you to fly out this way and take JP for a romp. T
Old Apr 29, 2014 | 05:32 PM
  #330
Dan87951's Avatar
Dan87951
Amazing work so far! Dare I ask what your running total is so far on this build?
