928 Forum 1978-1995
Sponsored by: 928 Specialists
Empty shell to finished car
Old 07-03-2014, 10:52 AM
  #376
Hilton
Hilton's Avatar
Originally Posted by FLYVMO
Granted, my dust covers were fairly worn, a little warped and cracked so perhaps new ones would fit?
No idea - I was curious as I noticed they were missing from both front and rear. I figured given your attention to detail it wasn't an oversight, I just haven't seen many pics of the hypercoil setup.
Old 07-03-2014, 12:18 PM
  #377
tv
tv's Avatar
I hope that answers what you were asking? I sure would love to see a 928 in that color, it would really accentuate the flowing lines.
Cheers!
Carl
Sure does, thank you
Old 07-03-2014, 05:17 PM
  #378
DZGunner
DZGunner's Avatar
hey, i noticed you have "door lock delete" in the description for your car, can you explain what you are doing for this, i really realllyy want to get a faster acting door lock with keyless entry. but i would still a want the option of manually locking and unlocking it from inside and out incase there was a battery issue you know. wierd example but the jeep liberty has a simple locking system thats just like how i described.
Old 07-03-2014, 05:58 PM
  #379
FLYVMO
FLYVMO's Avatar
I guess a more accurate label should be "exterior door lock delete". The ISIS electrical system has a built in security feature and door lock control through remotes. The interior door lock solenoids remain in place, and the InMotion controller controls them, either via a signal from the key FOBs or when the dash mounted lock button is pressed. Manual entry in case of a dead battery is possible by keeping the hatch lock. So this is a keyless entry with remotes, and can be controlled either via RF signal from the remotes, or via WiFI if that module is installed in the ISIS system.
Cheers!
Carl
Old 07-21-2014, 08:46 PM
  #380
FLYVMO
FLYVMO's Avatar
Some minor items done since last post; got the front coil overs installed, front Powercell fully wired and CanBus wires drawn to the cabin where they connect to the Mastercell. 8 AWG power wire installed to the ABS unit, and 33 Bar proportioning valve installed. Megafuses installed for the front Powercell that are fed by one 4 AWG power cable (not pictured yet) into two 60 AMP fuses and then to the power cell via two 8 AWG power cables. Located under the jump post terminal for short power run. 4 AWG power cable shown will run from jump post to cabin for main power to interior Powercell and InMotion controller. The CanBus wires carry power to the Mastercell so need for external power for that unit.
Cheers!
Carl
Old 07-21-2014, 09:38 PM
  #381
77tony
77tony's Avatar
Glad to admit, I do troll a few other car forums, re: www.pro-touring.com, www.benzworld.com, www.bmwfourums.com. etc, etc and this build is among the best that I have ever seen. Hats off to Carl on this amazing build and really look forward to the completion of this build. T T
Old 07-21-2014, 10:48 PM
  #382
Hilton
Hilton's Avatar
That wiring setup is just awesome.
Old 07-21-2014, 10:57 PM
  #383
FLYVMO
FLYVMO's Avatar
Hey Tony, thank you!
Hope I can get it up to JP's standards with all that horsepower
Cheers!
Carl
Old 07-21-2014, 11:13 PM
  #384
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,437 Likes on 1,366 Posts
Carl, great detail , thanks for sharing your work
Old 07-21-2014, 11:25 PM
  #385
77tony
77tony's Avatar
Cheers!
Carl
You did bring it up, what kind of hp are you planning for this project ? T
Old 07-21-2014, 11:35 PM
  #386
FLYVMO
FLYVMO's Avatar
6.7 Liters....550-ish
Old 07-21-2014, 11:43 PM
  #387
77tony
77tony's Avatar
Wow, 550ish out of a 32 valve motor ? T
Old 07-21-2014, 11:51 PM
  #388
FLYVMO
FLYVMO's Avatar
Oh no, it is out of a custom hand built 16 valve motor
Old 07-21-2014, 11:56 PM
  #389
77tony
77tony's Avatar
Really, what year 16V ? T
Old 07-22-2014, 12:01 AM
  #390
FLYVMO
FLYVMO's Avatar
Hmmm, you warned me about this day Tony
Model year 2014, hand built 6.7 stroker LS engine, LS3 ported heads, LS7 cam, Callies forged rotating assembly, FAST intake, drive-by-wire.
Subject to changes of course
Quick Reply: Empty shell to finished car
