Project REAR WW LINER - GTS & Others
#571
Jerry, you asked previously and I forgot to come back to you.
My 90 does NOT have the fixing point at the top of the rear wheel arch. Otherwise it has panels in the rear wheel arch front and back drivers side and front passenger rear wheel arch.
#573
I put a set of these in another 91 GT or S4 with GTS rear quarters in Arizona and they fit with some minor issue that I have not figured out. I think these will work in your 91, and we can coordinate the installation by phone and email if there turns out to be any issue.
#575
For my 928 GTS 1994 I removed both rear liners did some repair work and cleaned them up to have LINE-X applied to the inside surfaces,and they look good. The LINE-X is some type of rubber material and should last a long time. It is used for truck bed liners.
