928 Forum 1978-1995
Sponsored by: 928 Specialists
Blown headgasket, time to get dirty
Old 12-14-2010, 07:45 PM
  #46
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by SharkSkin
Hard to be 100% sure looking at that 3rd pic but it looks like you have either the wrong tensioner or wrong tensioner arm. The pushrod between the tensioner and arm should not be at that kind of angle. If it's just an optical illusion, great... but if it's not you'll want to "fix it right".
Look where the belt tensioning roller is on the belt.
The idler arm bushings must be missing.
Old 12-14-2010, 07:57 PM
  #47
dprantl
dprantl's Avatar
I am surprised that belt is still on and timing the cams at all. You can see uneven wear on the oil pump gear and the belt position difference between passenger and driver cams makes me feel queasy.
Dan
'91 928GT S/C 475hp/460lb.ft
Old 12-14-2010, 08:35 PM
  #48
Opelotus
Opelotus's Avatar
Originally Posted by GregBBRD
I understand the difficulty...but it isn't hard enought to warrant that..
The front and rear of the factory cam carrier gaskets that have the moly coating on them don't stick to the head or the cam carrier, while the center section will stick. They move and split. You can usually see this, by looking right along the outer edge.
Some people apply Gasacinch or some other contact adhesive to keep that gasket from moving while they are trying to get the cam carrier on....as it is pretty easy to tear that gasket. This is the "kiss of death" for that gasket. Might as well tear it iinto little pieces and install it. When I install the cam carriers, I always have a little "pile" of gaskets, so that I can throw away any that get "compromised" during installation....
It is a PITA, the first time...the second, third, and fifth times just make you crazy. You really need to do yourself a favor and throw that stock gasket in the trash, because if you are trying to learn what it takes to make that gasket work, on your own, you are going to need "wing nuts" on that engine before you are done.
Thanks for the input. Interesting. I actually tore one gasket near the coated portion during installation of the passenger side cam carrier, and funnily enough, the replacement I ordered at CarQuest the next day arrived torn at the same spot . It didn't occur to me that this was a weakness in the gasket... I'll do my best to see if I can spot a tear in the system.
Old 12-15-2010, 03:27 AM
  #49
Ad0911
Ad0911's Avatar
Is there a better quality aftermarket cam carrier gasket that is more easy to install?
Old 12-15-2010, 04:51 AM
  #50
GregBBRD
Former Sponsor
GregBBRD's Avatar
Yes. it was such a huge problem, for us and others, that we had a custom batch of gaskets cut from a different material. Obviously, we left off the "coating".
Old 12-15-2010, 04:56 AM
  #51
GregBBRD
Former Sponsor
GregBBRD's Avatar
That's the place.
If this gasket gets torqued unevenly, has any oil, has any other sealant, or gets even slightly overtorqued...it will split and push out.
Fortunately, this gasket got superceeded when we were doing a boatload of 944 engines, many years ago....so we were able to work out how to install it and use it (until we had some made) on that model...which is not nearly as hard as messing with the cam carrier on a 928!
I think if I had to learn the lessons on how to install and use that gasket on the 928 model, I might be working on different vehicles...
Old 12-15-2010, 03:08 PM
  #52
Emickelsen
Emickelsen's Avatar
Dont forget to break the crank bolt free while you can lock down the flywheel.
Do you have the engine removal instructions from the manual?
YES, already thought of that. Thanks for the reminder. Does anyone by chance know the socket size I will need to get that off? Do the pullys and vibration damper only fit on in one position, or do I need to mark it befor I pull it?
Yes I have the work shop manuals, thank god!!
Old 12-15-2010, 03:21 PM
  #53
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,704 Likes on 1,308 Posts
27 mm crank bolt. Note the orientation of the big-*** washer underneath the bolt. Damper needs to be on so you can read the numbers from the front of the engine. No orientation to the pulleys.
Old 12-15-2010, 07:52 PM
  #54
Emickelsen
Emickelsen's Avatar
Ccol thanks. So break it loose but leave it on until I have the engine out?
Old 12-15-2010, 08:01 PM
  #55
Rob Edwards
Archive Gatekeeper
No reason not to take the pulley off now, might give you that much more clearance if you decide to pull the engine, but it's not critical either way. Once the accessory belts are off, you should spray a little Kroil or PB blaster between the pulleys to start soaking the balancer to ease its removal, if it's not been off in a while.
Old 12-16-2010, 12:30 AM
  #56
Imo000
Captain Obvious
Super User
Imo000's Avatar
That's the place.
Is this the gasket at the back of the cam carrier and has 3 holes?
Old 12-16-2010, 02:15 AM
  #57
Emickelsen
Emickelsen's Avatar
Ok, i'm looking at my belt tensioner, and the shaft is at an angle. I did a lot of researching old posts on the subject, and the porkensioner seems the way to go. So, stupid question. I couldn't find where to get one? I asume I need the one with the air pump bracket?
Old 12-16-2010, 02:26 AM
  #58
Rob Edwards
Archive Gatekeeper
Roger's got 'em, and yes you need the airpump bracket version.
http://s287999742.e-shop.info/shop/a...52010%2520K%26
Old 12-16-2010, 02:30 AM
  #59
GregBBRD
Former Sponsor
GregBBRD's Avatar
No, not that lucky...that one is easy.
Old 12-16-2010, 10:10 AM
  #60
LT Texan
LT Texan's Avatar
Quick Reply: Blown headgasket, time to get dirty
