Carrera IIIs
18x8 57 offset Front 235/40 ZR18
18X10 58 offset Rear 265/40ZR18
These were off 2007 997 both wheels and tires. Some have opted for 225/40 fronts and 265/35 rears which get you closer to 25" diameter.
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Supercharged
The 18 x 11's fit very nicely - but depending on the tire, you may need a small spacer (3pm) and need to roll/flare the fender. My experience has been that there is quite a bit of variability in the actual widths of 295/35/18 tires. If you don't want to mess with an of that stuff, get the 18x10's and put a 265 to 285 tire.
Also, there is a seller on eBay called eurowheelsusa that I bought my aftermarket set from for I believe under $700. I don't see any Carrera III's listed in his store currently, but he may still carry them?
Dan
'91 928GT S/C
When it comes to rubber Andrews comment re. variability seems correct.
I currently run 275s on 17" x 10" turbo twists rears and they barely fit...........never would fit a 285 especially with a 3mm spacer.
Dan
'91 928GT S/C
