Max Jax Car Lift a users review and Group buy opportunity for P-cars will close...
#46
Supercharged
Blessed by Gretch and Bob for cross-posting.
Cross posted:
993 forum - https://rennlist.com/forums/993-foru...ml#post8039808
924/831/944/951/968 forum - https://rennlist.com/forums/924-931-...ml#post8039819
996 forum - https://rennlist.com/forums/996-foru...ml#post8039831
997 forum - https://rennlist.com/forums/997-foru...ml#post8039839
Cross posted:
#53
Chronic Tool Dropper
I've been debating a lift for a long while. When I built the garage extension, I optioned full-height cathedral ceiling. When the door went in, I worked on it myselft to make sure I could get the door to follow the ceiling for the clearance needed underneath for a full-height lift. Slab is 8"+ of 4000 PSI concrete, with a couple layers of #8 bar on 8" spacing. All ready for a lift. There's a floor layout for a Bend-Pak 10ACX wide-footprint assymetric two-post, printed on big paper and taped to one of the cabinets. For over two years now. I just couldn't get my arms around the idea that I would have the lift columns there all the time.
The 'solution' for me is the Max Jax product. The columns unbolt from the floor and move out of the way when not in use. I'll probably put an extra set of imbeds in the floor so I have both wide and narrow column location options. With the columns narrow, the doors won't open fully but there will be much easier walk-around clearance. Wide gives good interior access with doors wide open. The only downside is the 48" max lift height, and after a few discussions it's been determined that it won't be a serious issue. Earl G mentioned at Frenzy that he'd rather lay down on the creeper under the car vs. standing up; sitting might be the right compromise. Plus I can stop the lift anywhere below a couple feet and stuff a jackstand under each lift carriage for 'just right" work height underneath. All workable, and way beyond what most of us can do with jacks and stands now.
#55
FWIW, getting local delivery from a liftgate truck vs a bobtail has never been tougher than a phone call to the trucking company that does the last mile. I tip the driver for his extra work, which is usually bringing it out the back with a pallet jack and lowering it on the gate. His bigger job is usually finding my house and navigating the road and my long driveway.
#57
With final decisions pending from
pjg - LGL - Glenn M and firesm this group buy will close in the next 2-3 days
Payments will be made direct to Danmar - CC will be accepted and freight is included to a freight terminal in your area - some have asked if the 6 inch extenders to be included in the group buy - I'll ask when we're ready to place to order and let you know.
Best
Best
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#60
Archive Gatekeeper
I sent out some feeler e-mails to local concrete X-ray companies to find the cost to survey my damned post-tension slab for rebar. If that works out count me in, but this won't likely be in time for this group buy.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
