928 Forum 1978-1995
Sponsored by: 928 Specialists
Twin Turbo 928 fixed and back out there terrorizing the streets!
Old 06-04-2013, 10:35 AM
  #631
ptuomov
ptuomov's Avatar
Originally Posted by 123quattro
That is pretty much exactly where you want to be a for a max effort street engine.
Yes, these compressors are pretty much maxed out now.
John's notes:
I need to turn the boost down...it literally broke the tires loose on dry pavement in 3rd gear at like 70 mph during a roll on. ... It's to the point where it's just too risky to attempt any testing or tuning out on the street. ...It's very difficult to hold the throttle all the way down in 3rd gear on the highway, because the car accelerates very rapidly, even in the higher gears. ....when you come down on it, you literally feel your feet lift up off the floor due to the acceleration. It's pretty crazy and I'm sure the engine isn't loving being ridden that hard.
My conclusion:
Let's put in those bigger turbos!
Old 06-04-2013, 01:31 PM
  #632
eijun
eijun's Avatar
John's notes:I need to turn the boost down...it literally broke the tires loose on dry pavement in 3rd gear at like 70 mph during a roll on. ... It's to the point where it's just too risky to attempt any testing or tuning out on the street. ...It's very difficult to hold the throttle all the way down in 3rd gear on the highway, because the car accelerates very rapidly, even in the higher gears. ....when you come down on it, you literally feel your feet lift up off the floor due to the acceleration. It's pretty crazy and I'm sure the engine isn't loving being ridden that hard.
My conclusion:
My conclusion: Add some weight in the back (say 100-200lbs in incremental weights in the spare tire area) give it a test drive if you like you can then add a full heavy sound system in the back (not near the center rear seat, I mean the back back near the hatch); then add bigger turbos
Old 06-04-2013, 02:10 PM
  #633
ptuomov
ptuomov's Avatar
I have some layers of mass loaded vinyl there already. I guess I could just try to put some metal plates between them. And for testing we could replace the spare tire with say 45 pound bench press plates.
The above for testing this dyno mule. For the final car, the idea is to delete *everything* unnecessary from the front of the car and then move what can be moved of the rest to as far back as possible. I was thinking about creating some very simple .xls model of the weight distribution and then seeing where the moving gets you the most bang for the buck in terms of moving the center of gravity towards the center of the car and reducing the polar moment of inertia. Nothing has happened in practice here, it's been all engine all the time for a while now and it'll continue to be all engine for a little bit longer.
Old 06-04-2013, 02:39 PM
  #634
Tony
Tony's Avatar
at some point you have to ask what is it you want...a quick car or a powerful car.
I know the answer in ptuomovs case.
My car was actually quicker when configured with bigger pulley on it during a few "testing" stages. It launched in a more predicable manner.
Old 06-04-2013, 02:50 PM
  #635
eijun
eijun's Avatar
I know once its moving the weight shifts a little to the rear, my view point in general is center of the car for balance and handling and rear weight is for keeping the wheel on the ground.
For sudden acceleration you want to have more rear weight being you want the wheel on the ground while high speeds you want it balanced with the spoiler doing part of the rear weight job here.
An excel sheet can do the high speeds balanced thing easy, its the high acceleration which you need some type of formula which likely you can nab from a Carrera race forum or even a HondaAccord/MazdaMiata forum being they have a bigger street racer base with turbos/supercharged/nitro stuff (not perfect but the basic formula is closer than a Carrera formula being Carrera is usually not super modded due to the cost vs Japanese Rice Rockets)
The problem is trying to find the balance of which is acceptable for you (too much weight = slow; too little weight = no rear grip; too much rear weight = bad car balance; too much center weight = not enough rear grip)
Speed vs power... I don't think his car has hit that divide yet
Old 06-05-2013, 06:53 PM
  #636
ptuomov
ptuomov's Avatar
Right now it's all about power, and speed is a secondary consideration. Down the road, maybe we'll think about speed as an objective as well. So far we haven't.
That said, purely as an unintended byproduct, car is also getting faster...
In addition to finding the boost bottleneck, we've also come up with a new tuning hypothesis. The hypothesis is that we'll make the same peak power and wider power band at 650 ft-lb if we do the following:
(1) put in generous spacers to the intake manifold on both sides
(2) change the software such that the flappy is not opened before 5500 rpm, or maybe not at all.
We think this will be da bomb!
I am forecasting reader skepticism.
Now, don't get me wrong, I think that on a completely stock 928 S4, the intake manifold spacers marginally reduce the peak power. No +10hp gain there, more like -2hp loss! This about -2hp can be recovered with Sharktuning by keeping the flappy open at high rpms, but still even that gets you to about zero. Of course, nobody can reliably measure +/-2 hp on a chassis dyno, but you get the point. The plenum spacers don't give more peak power on the NA car, maybe a little unshourding benefit but that's it.
However, we're in the boost land. We are going to use the spacers to move the first torque peak from about 3150 rpm to about 2900 rpm by adding the largest available spacers. This was among the lessons learned in the intake manifold threads http://speedtalk.com/forum/viewtopic.php?f=1&t=35634 and https://rennlist.com/forums/928-foru...and-ideas.html. This "spacing out" the plenum will increase torque at low end where turbo is not yet fully spooled and thereby produce more exhaust gas to spool it earlier. We can easily fill the corresponding hole at 3400 rpm in the torque curve with boost. The result is -by my expectations- that we'll add about 100-150 rpm to peak torque region (>600 ft-lb) in the low end. We're not trying this in the next test, but the low compression engine will surely be get a completely "spaced out" intake manifold.
In the next test, we are planning not to open the flappy. On a normally aspirated car that would reduce the torque pretty dramatically at about 4200 rpm, which would be bad. On my turbo car, it's good! Why? Because we can detune the most detonation prone rpm range 3600-4800 rpm while still running the stiff wastegate spring we need to go into low twenties in terms of boost above 6000 rpm. Keeping the flappy closed will knock out about 10% of the torque at 4200 rpm, which in boost units is about the same as taking the boost down from 14 to 11.5 psi at 4200 rpm. In fact, it'll reduce knocks even more than just turning boost down from 14 to 11.5 psi because the intercooler sees hotter charge that is then expanded in the manifold to be colder (a la new Carrera Turbo expansion intake manifold).
Furthermore, not opening the flappy when Bruce Banner is turning green from biting his lip makes tuning a whole lot easier without tripping knock retard and sending the torque curve to the EZK penalty box. This in turn will allow us to tweak the column rpm definitions in the software and move some columns from the mid range and to the above 6000 rpm where power is made. If the flappy trick works in this test, the next test will see whole different fuel and spark maps.
Old 06-11-2013, 09:16 PM
  #637
ptuomov
ptuomov's Avatar
A quick update:
The stock engine won.
The compressors have hit the centrifugal compressor choke point, aka "stonewall". By our math, in the last dyno experiment the compressor internal air speed went sonic, which creates a sonic wall after which the mass flow rate doesn't really increase with turbine speed. This means that the gt3071r-wg turbochargers are completely maxed out on the compressor side. The stock engine held, without any problems, the maximum amount of air that we could throw at it with these turbos.
I am impressed by what the factory put together there in 1987.
Old 06-11-2013, 09:27 PM
  #638
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Oh brother, somebody gonna kiss the donkey!
Old 07-13-2013, 01:09 AM
  #639
U-928
U-928's Avatar
Soooo...... Updates!?
Old 07-13-2013, 05:06 PM
  #640
andy-gts
andy-gts's Avatar
how much psi have you pushed this too...that is when compressors are Maxxed out!! this is so awesome!!!
andy
Old 07-14-2013, 11:30 AM
  #641
ptuomov
ptuomov's Avatar
Update:
The gt3071r compressor hit the sonic choke which means that the intake become mass-flow limited. With this stock engine and this tune, what it means is that once the car hits 700 rwhp at some rpm it can hold about that same horsepower level up the rpm band but not produce more power. The boost becomes irrelevant, it's the mass flow that is now fixed.
This left us at a cross-roads: Either start optimizing the engine to be as efficient as possible in using that capped air flow level better or swap in larger compressors.
We've chosen the second path. The car is on a lift and the old turbos are off. Custom turbos are being built as no stock Garrett turbos fit in the space we have. The compressor cover starts life as a Garrett part number, but needs to be cut, welded, and remachined. The turbine cover starts life as a stainless steel aftermarket turbine housing, but needs to be cut, welded, and remachined. The exhaust manifolds need to be modified to fit these custom turbos. New downpipes are needed as well. The next step is to get the engine running with this new, proof of concept turbos.
Once the proof of concept turbos are ready and tested, the stock engine will come out and the low-compression hot-rodded engine will go in. The final version of the turbos will be built and TBC coated, speed sensors fitted, etc.
Old 07-14-2013, 11:28 PM
  #642
blau928
blau928's Avatar
Tuomo,
Would a GTX3076 or GT3582 cold side fit with the existing hot sides? Or is the space available the criteria for fitment...? Also, will you guys be using external wastegates or sticking with the internal..?
I am curious, as I have been debating something silly with my silly self...
Old 07-15-2013, 12:09 AM
  #643
ptuomov
ptuomov's Avatar
Originally Posted by blau928
Tuomo, Would a GTX3076 or GT3582 cold side fit with the existing hot sides? Or is the space available the criteria for fitment...? Also, will you guys be using external wastegates or sticking with the internal..? I am curious, as I have been debating something silly with my silly self...
John's got some opinions on this, as do I. Right now, the hot side flows enough. However, if we'll be moving 40% more air thru the cold side, the hot side will also choke down and the wastegate circuit at minimum needs to be rethought. We have a couple of options here and it's not like they are state secrets but I don't want to write about specifics before we have a working proof of concepts. So more about the solution once the solution works as is actually a solution.
Everything would be really easy to size and select if it weren't for the real estate problem. Almost nothing fits under there. If it weren't for the space constraints, we'd probably stick a couple of GTX3582R's under there and be done with it. Or a couple of twin-scroll turbos, pairing 1+2, 3+4, 5+7, 6+8. But this is all worthless daydreaming as there is no room whatsoever for off-the-shelf turbos and ideal manifolds.
Old 07-15-2013, 01:51 AM
  #644
blau928
blau928's Avatar
Ok, got it.. I like the idea of the 3582's, but my main concern was also real estate.. I'll keep an eye out for your updates..
Best,
Old 07-15-2013, 06:53 AM
  #645
Thom
Thom's Avatar
How much back pressure are you seeing now, and with what A/R size on the turbine housings?
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
