Twin Turbo 928 fixed and back out there terrorizing the streets!
#1893
Archive Gatekeeper
Tuomo, when's your beastie coming back to MA?
#1894
The car is being shaken down on John's dyno. There are loose connections and some minor faults to hunt and fix, so it’s being shaken down without putting down any significant power. 600 rwhp runs just to check everything and bug hunt. Dyno sensor calibrations to do, and there’s probably one more loose connection in the car.
#1898
One thing to note is that at constant boost (and massively retarded timing) as in those shakedown runs, the engine really wants to make good torque in the 4500-6000 rpm range. This is exactly as expected, given the exhaust blowdown interference with exhaust manifolds. These Elgin 65-6 cams on 114 LSA would really benefit from long-tube headers in a normally aspirated car, the mid range would get boosted up a lot and the torque curve would extend further. In the turbo case, as long as we can deal with knock due to large residual exhaust fraction, it'll be easy to just tailor the boost profile per rpm to create a flat torque curve. Today, we should find out how much the cylinder specific ignition timing helps in keeping the knock counts down with higher boost.
#1900
Knock sensor connected
This is with knock sensor connection fixed and no other tuning changes. It’s running ok, but there are more tuning to be done.
#1901
Archive Gatekeeper
LOL, that's getting close to 'preposterous'. Well done!
#1902
Received 1,543 Likes
Yup. This is some ‘next level $h1+’.
Preposterous is, in my mind, a number consisting of four digits in units of bhp.
So, at about 870(*) rwhp we’ll (vicariously, through Tuomo) have crossed that Rubicon.
* I’ve always used a 13% loss for a 5-speed 928.
Team Tuomo and Kunn are about 190 rwhp away.
#1903
It will not want to go to 870 rwhp with pump gas. Just not enough octane.
On the positive side, the turbine outlet pressure is down a full pound per square inch with the new exhaust. And the new exhaust is quieter than the old, more restrictive one.
#1904
More de-buggery
More debugging at the Kuhn lab... the wideband oxygen sensor is malfunctioning. One boost pipe needs to be tightened, popped out and made a small dent to the car. John’s notebook also having some issues, so new computer coming tomorrow. John’s calling it a day today.
No oil out of the breather system at all.
The next order of business tomorrow is to try to extend that torque curve as flat as possible past 5800 by suppressing knocks in cylinders #1 and #6 and then possibly upping boost.
#1905
Physical road simulation
Here is the setup to simulate the air flow on the road. With the hood open, one doesn’t really get the ram pressure in the filter but other than that it’s probably pretty realistic:
