928 Forum 1978-1995
Sponsored by: 928 Specialists
Twin Turbo 928 fixed and back out there terrorizing the streets!
Old 01-06-2018, 12:32 PM
  #1816
FredR
FredR's Avatar
Tuomo,
What is happening with your monster motor at the moment?
Apologies if I have missed anything
Old 01-06-2018, 12:50 PM
  #1817
ptuomov
ptuomov's Avatar
Originally Posted by simos
Tuomo, have you seen this Mazda VRIS study, perhaps nothing new for you but good write up.
http://web.archive.org/web/200312062...vwxyz_vris.htm
I think that this writeup is a little confused about the Mazda V6. The original SAE paper explains things a lot better.
In any case, the Mazda V6 intake is similar to many Porsche intakes that have a resonance flappy, including the 928 S4 intake. There are two modes, and they tune to different frequencies.
My plan is to fine tune the turbine A/R choice and the intake manifold resonance point such that the intake flappy-closed torque peak happens at the rpm where the turbine is just about to spool such that the knock limit is reached at the lowest rpm possible without sacrificing the high-rpm exhaust manifold back pressure. At high rpms, the flappy can be left open because the resonance effects are minor and because the throttle body flow resistance imbalance is mitigated by there being net air mass flow from one plenum to another thru the resonance flappy pipe.
Old 01-06-2018, 02:26 PM
  #1818
V2Rocket
Rainman
V2Rocket's Avatar
I used to have a car with that engine - very smooth power delivery and a great sound, FWIW...
Speaking of Porsche + Mazda V6, Porsche designed the original Ford Duratec V6 for possible use in the Boxster, then sold the design rights to Ford who tweaked it a little for mass manufacture.
Old 01-06-2018, 06:59 PM
  #1819
ptuomov
ptuomov's Avatar
Originally Posted by FredR
Tuomo,
Final adjustments and assembly:
Old 01-07-2018, 09:37 AM
  #1820
ptuomov
ptuomov's Avatar
Default Bumper adjustment
There is now enough clearance between the rear bumper and the tailpipe such that the bumper doesn’t melt during the first couple hundred dyno pulls:
Old 01-08-2018, 08:03 AM
  #1821
Chris Lockhart
Chris Lockhart's Avatar
Damn that is beautiful Tuomo!!!! Kudos to you and Mr. Kuhn.
Old 01-20-2018, 12:37 PM
  #1822
ptuomov
ptuomov's Avatar
Test pipes welded and a cheap thermal imaging system purchased:
Purely by coincidence, the "test pipes" that replace cats and work as exhaust blowndown supersonic shock wave traps happened to be exactly the right length for the spot. Better be lucky than good! Stainless steel, robot welded in Taiwan:
Then there's the question of heat shield design. We're planning to do the simplest thing, which is to drive the car hard and thermally image the engine and pipes from the top and bottom right after that. This should tell us if any sensitive components are getting any heat. Special attention will be paid on the valve cover gaskets, oil pan gasket, scavenge oil pump, and the starter motor. Below I used the system to turn my oldest into a ghost:
Old 01-20-2018, 04:21 PM
  #1823
Imo000
Captain Obvious
Super User
Imo000's Avatar
Yup, I had a Ford Countour with it and a 5-speed, it was quick would have done well in the Boxter.
Old 01-20-2018, 11:07 PM
  #1824
andy-gts
andy-gts's Avatar
Cant believe this has been going on since 2010......
Old 01-20-2018, 11:32 PM
  #1825
ptuomov
ptuomov's Avatar
Its a science project. I drove it for a while, but more is never enough...
Old 01-21-2018, 01:46 PM
  #1826
ptuomov
ptuomov's Avatar
Default John’s about ready with the exhaust
Here’s the exhaust. While John Kuhn is putting the finishing touches on the exhaust, Im helping Olivia guard the basket against Orlando Magic:
Old 02-03-2018, 09:08 PM
  #1827
Roy928tt
Roy928tt's Avatar
Given the mention of the Mazda K series engine, and the twin turbo theme I thought I might just throw this in the mix. This is what I've been doing lately, it is the back end of a 1988 F1 car mated to a Mazda KL and a tube frame chassis at the front. For use at my local hillclimb track.
Old 02-04-2018, 05:57 PM
  #1828
ptuomov
ptuomov's Avatar
Default Polished
The tip is now polished and all the pipe section dimensions recorded such that John can make more of these exhaust if people need the flow capacity and like the sound.
Old 02-04-2018, 09:43 PM
  #1829
Bigfoot928
Bigfoot928's Avatar
what are the details of the rear muffler? Dual 3 in and 3.5 out? I need to redo the back of my exhaust to fit around the z06 trans so I may as well add a muffler. I have dual Borla XR1 Race mufflers and it's a tad bit loud.
Old 02-04-2018, 10:19 PM
  #1830
ptuomov
ptuomov's Avatar
Dual 3.5” in and single 4.5” out. Could be easily made dual 3” in and single 3.5" or single 4" out.
In terms of sound, the theory is that the infinity pipe and single out will help a lot. In theory, theory and practice are the same. In practice, we’ll see soon.
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
