Twin Turbo 928 fixed and back out there terrorizing the streets!
#1771
Can I get some action — from the back section
Custom offset inlet outlet mufflers in front of the rear axle could add some volume, but in terms of flow area this is pretty much the largest one can go.
Personally, I think John’s designed and fabricated a really beautiful exhaust system:
#1772
Archive Gatekeeper
Beautiful work! When the left rear tire goes through a pothole, how close does the control arm articulate to the outer pre-muffler pipe? Probably an optical illusion but it looks really close.
#1773
Shouldn't be a problem. Those pictures don’t communicate the third dimension very well. It shouldn’t be any closer there than the previous 3” systems.
#1776
In in all seriousness, this is a street car on street tires. To make this combo live healthy on slicks on track for an hour would mean changing a lot of things.
#1777
I wish you guys would have made some type of quick disconnect for the rear muffler. I'd love to see Dyno numbers and readings with and without it. I have a feeling that muffler is gonna cause some problems.
#1778
Why do you think the rear muffler would cause problems?
#1781
#1784
Although I think 4” at the tail pipe would be enough, I think 4.5” is good for experimentation as we can use inserts in that tail pipe to reduce the diameter and see how that impacts power and sound.
