New Product from 928sRus - Enhanced Intake System
#241
Here is a functional fit-up on an 84 Euro S.
It and its 85 and 86 Euro S brothers, for those who might not be familiar, uses the same round MAF as the 32 valve cars.
I really like the way the intake fits and looks on both AFM- and MAF-equipped 16V cars.
In both cases, it opens space behind the spiderpipes for access and cooling. That space is usually packed-full with the factory airbox.
#242
What Roger said, 31" max, bow to port - a real difficult stack-up.
It was critical work with Spectre's design and maintain is functional intent as close as possible.
Roger, he's right about the cobrahead elbows, they're pricey - $36 each. I bet you'll be able to better that.
The setup allows the 4inch tube to go right up to the 3 1/2 inch.
Look at the id of the filter it is about 3" id when inside a 4inch tube
and the Y pipe is only about .1id larger per side so the flow is going right in and can be joined together with the rubbers.
The overall can vary 30 to 31inch max.
The rubber setup saves space 1inch per side as they will go right together as pictured without the rubbers on.
Lower cost with 4 inch tubes instead of 4 inch canisters if that is what they are using?
There is also no longer a need to buy the canisters.
Rubbers insert are under $9 a side.
Canisters are more $
Cobra heads more $
Y pipe welding on ends is more $
The entry into the canister is alot smaller too into the filter cone area.
The system you have is good but this is something you could try to build them for less money so
others can afford them easier.
Are they 4 inch canisters?If so then this may work.
#243
Thanks M928. Yes, they're 4" filter housings.
I believe I understand what you've suggested. Suggestions noted.
This is just a prototype and cost structures may not be as apparent as you make them them out to be.
It is quite possible, the cobraheads may not be used.
It is quite possible the end design may only resemble this prototype, but general construction may utilize different methods.
Part of what makes this design work is it is "stockish", looks good, and has a high level of mfg. method flexibility.
I hope that it flows nicely too.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I'm going for something a little more cohesive than assembly a semi-elaborate group of pipes/adapters/reducers - no offense to anyone.
Ultimately it's for Roger to choose how he wants the project to develop. I'm just out here having fun, trying to create something befitting a modified 928.
#244
I have been looking for a way to shorten the system up also and came across the inserts.They were 1.25 long having them trimmed back to about .75 wide which will be flush at the end of the Y pipe.Once that goes over the Y pipe just slide the 4inch rubber sleeve over it and clamp it,that brings the 4inch pipe flush to the 3 1/2 Y pipe.The filter still flows into it as it is alittle smaller id than the opening of the Y pipe.
You only need about 1/2 on the Y pipe as the worm clamp is that width.
I was going to weld a 1/2 inch wide 4inch collar on the Y pipe on each end but going in toward the center which would do the same save more space but going to use the rubbers for now.Marked picture about welding collars inward, also then regular 4inch clamp there might be easier to fabricate on welding it on?
Its just an idea before for Roger gets into making them.
Another reason why I like this setup is right before the raidus of the elbow the filters go into the straight of the elbow only(without entering it)part of the filter nose cone is now into the straight of the (4" id rubber) which allows more flow around the nose cone as its in the 4inch id instead of internal 3.8inch id tube.
Inserts are at:
http://intakehoses.com/Merchant2/mer...egory_Code=RIS
#245
Under the Lift
Not sure if you are running the 4inch canisters but to save alot of cost
you might want to try this instead of all the extra fabrication on the ends
of the Y pipe and the cost of the canister.
Cut Y pipe to around 7 or 8 inches long or just enough which allows for
the rubber to be clamped easy.
Since the 4 inch tubes have the inserted filters the outlets of those
filters are around 3inches which would flow directly into the 3.5 Y pipe.
The opening on the 3.5 Y pipe may vary depending on wall thinkness used
but usually is around 3.2 to 3.3 inches so the 3inch opening of the filter
dumps right into the Y pipe without all the fabrication to areas marked A and B.
Using the 4 inch straight rubber and the reducing rubber inserts.
The rubber inserts can also be trimmed back some to put the filter right
flush against the Y pipe if needing more space.That may give room also
so you won't have too buy the expensive Cobra rubbers.I am having my
reducer trimmed back so there isn't any space between the Y pipe and
4 inch pipe which gives me more room so I dont have to use the cobra
style rubber,less cost and better flow.
#246
Have any of you yet run the system with the filters right up against the Y? The reason I ask is that I saw some idle surge problems with a supercharger intake that had some diameter transitions and 90 degree bends right next to the MAF. My theory was that this created a turbulent flow that confused the MAF. If I removed the intake tubing the idle stabilized. The filter could cause a fair amount of directional flow change and turbulence to the intake air. If it were further away from the MAF it would have more opportunity to settle down. Just wondering.
Haven't tried it yet you may be right thou on the airflow maybe more so under pressure with supercharger etc?On the 4 inch pipe with the filter in it,the filter is 3" id outlet going into around 3.25" id on the Y pipe so only 1/8inch per side difference but won't be able to test that out till spring.
#247
Captain Obvious
Super User
Super User
#248
Under the Lift
Bill,
#249
Bill,
Took some picture to show what the filter looks like inside the 4inch tube and how it looks from inside the Y pipe.
Those filters are about 3inch id on the outlet.It may also possible to put a chamfer on the rubber of the filter to really blend it if needed.
It dumps right into the Y pipe not sure if it will effect idle.The rubber on the right pipe is to show the reducer which let me shorten the systemup.
It can be made to under 30inches.The left pipe is 7inch and the filter cone is even with it not into the elbow.
With the (3 1/2 to 4 inch rubber that I had)the system was 1 inch longer per side and the filters would go into the elbows thats why the use on the reducer rubbers which put the filter flush to the Y pipe.I had to get the filters out back in order to setup the fan system.This is to just let Roger know what I am trying incase he makes changes later
on also on the later models with filters out back.
#251
Prototype stage. Developed for L-jet (80-84 US), and LH-Jet (84-86 Euro).
Sorry bud, packaging for the CIS OB's is a bugger due to the major "jog" to get from the airbox to the air-meter plate.
#252
What about a U.S. '85 version?
#253
Brian,
That was the first one the prototype was developed for, however the the major issue was cornering the "pipe organ" intake around the back corners.
It will require a very special elbow which is not in the near-term development plan.
Long-term development shows it as quite a possibility.
#254
Capital expense for custom corners for 85-86 US.... $2-4K.
I have some interesting design configurations using carbon fibre, but will have to develop capital first.
Will have to start off with the simpler design, and work our way into something more elaborate.
