928 Forum 1978-1995
Sponsored by: 928 Specialists
My son's 1980 repaint begins.
Old 10-16-2010, 10:28 AM
  #226
dr bob
Chronic Tool Dropper
dr bob's Avatar
Originally Posted by Mrmerlin
please take the time to jack up the car put it on jack stands and remove the wheels,
after all of this time it will result in a more thorough paint job I promise
+928
Having the car up means that the critical doors and lowers will be high enough to see the paint flowing as you spray. Too many DIY jobs are plagued with dry lower sections or runs in the doors where the painter couldn't see well enough down close to the floor.
Keep up the great work and the pictures.
Old 10-17-2010, 07:40 PM
  #227
Dean_Fuller
Dean_Fuller's Avatar
Almost there. Body is 95% ready and I still need to tape the wheel wells. The olive green is etching primer I added where I sanded through to steel. I STILL have about 6 small sand through areas I need to fix. I am sure if the weather holds that this time monday...it will be painted!
Old 10-17-2010, 10:07 PM
  #228
Jerry Feather
Jerry Feather's Avatar
Dean, Your passenger door fits very nicely, but you driver's door is slightly off. It needs a very thin shim between the upper hinge and the hinge pocket. I have made some of these shims for another lister in the past and will send you a couple for fitting purposes if you want. PM me your address and I will send you a couple to try to lift the back of that door a tiny bit to be perfect. Jerry Feather
Old 10-17-2010, 10:15 PM
  #229
pcar928fan
pcar928fan's Avatar
Jerry,
I think it might be a trick of the paint from the jamb painting... Look at the leading edge of the door. That looks pretty damn good to me... though, you are the pro, so my eye is not as attuned to these things as yours, but I certainly can't detect anything from that clean leading edge.
Dean, great work...I just can't wait to see this thing done and I REALLY, REALLY hope I get to see it in person at some point...
Old 10-17-2010, 10:20 PM
  #230
SeanR
SeanR's Avatar
Hey Dean, ya looking to trade some work out?
Old 10-17-2010, 10:30 PM
  #231
Dave928S
Dave928S's Avatar
Impressive!! ... I've been following this thread and I admire you're dedication to getting the job done right under less than prefect conditions. Kudos to you for your determination and perseverance ... you haven't let anything beat you .. your son is lucky to have a dad like you Can't wait to see the finished job.
Old 10-18-2010, 12:56 AM
  #232
Jerry Feather
Originally Posted by pcar928fan
Jerry,
I'm no pro, but for me the tell tail indication is how close the gap is at the rear of the bottom of the door, and then when you look around the rest of it you can see the tiny bit of difference in the other gaps.
Jerry
Old 10-18-2010, 01:04 AM
  #233
Jim M.
Jim M.'s Avatar
I think Jerry may be correct, but without the latch installed the door may not be completly closed and flush. YMMV
Old 10-18-2010, 02:46 AM
  #234
pcar928fan
pcar928fan's Avatar
I was thinking exactly what Jim posted when I read your post Jerry. Could also be that the hinges have not been tightened down yet too...
Old 10-18-2010, 04:37 AM
  #235
Jantje Vlaam
Jantje Vlaam's Avatar
If you are going to paint te whole car at once for optimal colour quality, why aren't you respraying the roof to make sure everything will look te same. Different temp and humitity can change a colours appearance a little.
Old 10-18-2010, 06:28 AM
  #236
riviera455
riviera455's Avatar
cant wait to see this one in green,
verry nice work! great color!
be carefull using the cheap magazine paper , they suck up paint and stick on the car if they touch , and they also leave small gaps possible that blow open when u spray.unless u use a lot of tape to close the gaps.
better to use brown paper in one piece,
Old 10-18-2010, 12:14 PM
  #237
AO
Supercharged
AO's Avatar
Dean,
What a spectacular photodocumentary. I've been watching your progress. Very cool project. I'd love to do one like it someday. Can't wait to see the final results.
Old 10-18-2010, 07:49 PM
  #238
Dean_Fuller
Took about 4 coats of color to cover the different primer colors..NOTE..USE SAME COLOR PRIMER on all final panels or you may have to use too much paint like me.
I have several runs in the clear as well as my light was failing. Those will sand out.
I may take more pics tomorrow in better light.
Old 10-18-2010, 07:54 PM
  #239
AO
Supercharged
AO's Avatar
Awesome!
Old 10-18-2010, 07:55 PM
  #240
J.Khan
J.Khan's Avatar
that looks great. nice work!
Quick Reply: My son's 1980 repaint begins.
