Comprehensive S4+ bolt lengths and torque values spreadsheet
Received 1,589 Likes
The geek side of me says that we should save the file in tab-delimited format and put it under source control so that we can manage simultaneous edits.
Anybody have a CVS or SVR instance running on a port we can get to?
Supercharged
I tried to use this a bit, but the 8 or so pages was a bit too much.
So I reformatted it to fit on to a sigle sheet of paper (front & back). I also filled in a couple of values.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
http://members.rennlist.org/andrewmo...%209-25-09.xls
Zirconocene (02-16-2020)
Archive Gatekeeper
Andrew-
Sweet! That's much better, and now laminatable as a single card. Just gotta alphabetize things (and make sure the values are all correct....)
Supercharged
Not sure how you could alphabatize things in a meaningful way... Maybe it would make sense to order them by bolt size? Just a thought.
Archive Gatekeeper
Just need to multiply the values by 1.35582, y'all can't do that on the fly?
I'll add a column of Nm values when I get a chance. Will also try to add all the automatic transmission values as well.
Wow guys, thanks for this.
When I had the snip snip I couldn't concentrate on anything.....Cudo's
