928 Forum 1978-1995
Sponsored by: 928 Specialists
Rob's GTS engine pull
Old 05-13-2009, 11:01 PM
  #46
GRTWHT
GRTWHT's Avatar
Thats bad luck with your engine guys. Although the damage is quite local to one rod assembly, could have been worse!
Looks like plenty of oil was getting to the failed rod, no blueing of the damaged bits, no molten bits of metal. Looks to me like the rod nuts have come loose and have left the building.
Rod bolts are strong but will snap in a brutal situation like that if the nuts hang on that is.
Lovely looking car, I'd be feeling crappy to see mine that way. Hope the repairs go well.
Glenn
'81 928
Australia
Old 05-13-2009, 11:38 PM
  #47
cold_beer839
cold_beer839's Avatar
Were these the early rods that were known to be bad, or the later rods?
Old 05-14-2009, 12:03 AM
  #48
RyanPerrella
RyanPerrella's Avatar
yes they are 1R rods
1R rods were found in all 92 (Early 93) 93 and probably half of all 94 model year GTS's
Old 05-14-2009, 01:53 AM
  #49
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
But the rod design is not the issue, here.
Old 05-14-2009, 01:57 AM
  #50
GregBBRD
Former Sponsor
GregBBRD's Avatar
Originally Posted by IcemanG17
Rob
Isn't that the inside counterweights....so the normal cranks with only 6 counterweights don't have a counterweight there, only GTS cranks and stroker cranks with 8 counterweights?
Yes. Unique to GTS cranks.
Hopefully no one is still having stroker cranks built with 8 counterweights. That's right up there with running Chevy rods.
Old 05-14-2009, 03:09 AM
  #51
RyanPerrella
yeah it appears it was the bearing , or was it oiling which caused the bearing to disappear?
Chicken or the egg?
Old 05-14-2009, 03:14 AM
  #52
GRTWHT
GRTWHT's Avatar
Loose rod nuts would be my verdict looking at it from quite a distance though
Glenn
'81 928
Australia
Old 05-14-2009, 04:25 AM
  #53
Vilhuer
Vilhuer's Avatar
Sadly its very likely at least one cylinder wall will have damage due to extra metal in circulation. Hopefully so mild that oversize piston will fix it.
Old 05-14-2009, 09:28 AM
  #54
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,169 Likes on 1,226 Posts
Old 05-14-2009, 10:46 AM
  #55
cold_beer839
^^^^^HEHEHEHEHEHEHEHEHE!!!!!!!!!!!!!!!!!!
Old 05-14-2009, 10:54 AM
  #56
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,707 Likes on 1,310 Posts
Hacker, you should see my day job. At least that elephant is alive.....
Besides, it was a GTS motor, not a 426 Chrysler.
Old 05-14-2009, 01:06 PM
  #57
thal
thal's Avatar
almost there...almost there...
Old 05-14-2009, 01:23 PM
  #58
RyanPerrella
Originally Posted by Hacker-Pschorr
BRILLIANT !
Thats awesome, how long did it take you to find the right image and then to produce what you have there? THATS AWESOME
Old 05-14-2009, 02:22 PM
  #59
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Racing just hasn't been exciting enough lately so I've been trying out a few other hobbies.
Old 05-14-2009, 02:41 PM
  #60
86'928S MeteorGrey
86'928S MeteorGrey's Avatar
That's gonna be one FAST elephant when they're done with it...
Quick Reply: Rob's GTS engine pull
