928 Forum 1978-1995
Sponsored by: 928 Specialists
Areo mirror substitute?
Old Aug 12, 2007 | 05:55 PM
RicerSchnitzzle's Avatar
RicerSchnitzzle
Default Areo mirror substitute?
I want to go with a set of aero mirros but can't justify the $500+
One thought is to go with used Miate mirros @ $100 pair shipped for power units. I've seen 2 other sharks with them and they look alright.
I just saw these on ebay. Has any one tried this approach? Not power but might look pretty cool. It's hard to tell from the pic if the angle will be okay. Looks like it only adjust up and down, not on a ball joint.
Here's the link. Googling them brings up mostly VW links for them. Can;t find a pic of them on a car.
Here's the ebay link.
Old Aug 12, 2007 | 06:23 PM
RyanPerrella's Avatar
RyanPerrella
Aero Mirrors are $340
Old Aug 12, 2007 | 06:29 PM
Brad W's Avatar
Brad W
I bought a set for $400 from Roger Tyson Brand new in the box (some assembly required)
Old Aug 12, 2007 | 08:14 PM
Jim M.'s Avatar
Jim M.
Someone on this list has the Miata mirrors on his 928. Big Dave is it you????
Jim Mayzurk
93 GTS 5-spd
Old Aug 12, 2007 | 09:14 PM
borland's Avatar
borland
Considering what I paid to have my fiberglass rear wing and aero mirrors painted, the parts were a relative bargain.
Old Aug 12, 2007 | 09:32 PM
redpathtribe's Avatar
redpathtribe
Not to highjack the thread, but I need to get this done as well... borland, how much did it cost you to paint the wing and mirrors? Was it any special color, or a stock Porsche color?
Old Aug 12, 2007 | 09:52 PM
RyanPerrella
Rick, you will spend a bunch getting the rubber coating off your wing to paint it
you may consider buying a GTS glass replica from someone for like $250
then you can keep the original or sell it to most likely offset the entire cost of the new wing.
Old Aug 12, 2007 | 10:03 PM
redpathtribe
Hey Ryan, Yea, I've considered getting a GTS replica wing, but have heard stories about poor finish needing a lot of prep, and bolt holes not lining up, etc.
I've read the write up from the 928OC site (IIRC) about prepping a pre GTS wing. Sounds like mostly labor/prep, which I'm hoping I can probably do a lot of. Would love to find a real GTS wing, but if I can't, I still may get a spare pre GTS wing to prep and paint and still have the stock original one if that doesn't go well.
Old Aug 12, 2007 | 11:08 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
You can use Miata mirrors, Mini Cooper mirrors, Corvette convertable mirrors. I have been paying attention to which cars gave door mounted mirrors as I plan on doing the same. Theres not many cars that use door mounted mirrors anymore.
Old Aug 12, 2007 | 11:11 PM
borland's Avatar
borland
It was a few years ago, so I don't recall the price I paid for painting. I wanted it done right the first time, so I found a highly recommended custom car painter in Ventura on the recommendation of another local shop (interior shop).
He used BASF Glasuric base coat, mixed to the Porsche paint color code, so it matched the car perfectly. I think just the Glasuric base coat was close to $50 a quart, which is what a only slightly more than he needed. There was also a side molding rub strip that was also done.
Old Aug 12, 2007 | 11:21 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Jim Mayzurk
93 GTS 5-spd
Nope. We do have a local guy with Chevy SSR mirrors, though.
Old Aug 12, 2007 | 11:31 PM
AO's Avatar
AO
Supercharged
They were NOT direct bolt on from what I understand.
Old Aug 13, 2007 | 12:46 AM
chaadster's Avatar
chaadster
Here's a pic of Matt's car with the SSR mirrors:
Old Aug 13, 2007 | 12:55 AM
Mike Simard's Avatar
Mike Simard
Thanks for the link Terra, those are what I had in mind for my racer. I bought a pair and will be glad to post some pics. These and probably most non-original mirrors will require plugging some holes on the door, our doors have a 3 holes that cover a large area.
Old Aug 13, 2007 | 02:47 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
If your going to install other than factory mirrors, disassembel the door and see where your mounting to, there are doublers inside the door and you will want to mount in this loaction otherwise the door skin will bend very easily , it is made of sheet aluminum
