928 Forum 1978-1995
Sponsored by: 928 Specialists
Hope for the poor old '85/'86 engines.
Old 04-16-2007, 02:32 PM
  #46
BC
BC's Avatar
Originally Posted by GregBBRD
It's hard to compare stuff without doing back to back testing. The problems I've had before with crank scrapers on a 928 is that the oil tends to get trapped on top of them on the 1-4 side and then gets into a continuous loop of trying to get by the scraper and being pushed back up towards the head. The 928 engine is somewhat unique in that the fact that the oil returning from the heads and camshafts runs down the sides of the block. I really didn't want to interfere with this oil return path, so I skipped the scrapers. The side mount pieces on the screens were designed to block the "sloshing" of the oil when the car goes around corners, while allowing the oil to return without resistance, to the pan. This stuff is definately not some simple grating that is stuck down there and a spacer. There's a bit more there than meets the initial inspection.
gb
Thanks for the response. So the scraper itself is exactly where the oil is coming down the side of the engine.
Old 04-16-2007, 03:29 PM
  #47
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,104 Likes on 1,196 Posts
Put me down for a set whent hey become available. Mid summer I hope to start working on my new track motor.
Old 04-16-2007, 03:31 PM
  #48
BC
BC's Avatar
Originally Posted by Sterling
The Kevin johnson scraper has shields that deflect the oil draining away from the scraper....... I bought the whole kit from him and still had oil ingestion issues afterwards.......
So can we review the results gotten with this screen-type system and what you installed, and I purchased and still have waiting for install? I can't find the pics of the changes that Kevin made to the sides for this oil drain back issue.
Old 04-16-2007, 03:45 PM
  #49
BC
BC's Avatar
Done:
https://rennlist.com/forums/928-forum/345289-discussion-of-different-oil-control-solutions-on-928s.html
Old 04-16-2007, 03:46 PM
  #50
BC
BC's Avatar
gb
How is the pan then sealed to the block? With two seals - one on each side of the spacer?
Old 04-16-2007, 09:55 PM
  #51
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,470 Likes on 1,466 Posts
Pan and spacer are installed without any gaskets. Used studs and nuts instead of bolts. Looking for any rigidity I can find for the bottom end.
Louis: Not much to look at. The oil pick-up is stock. I just built spacers to move it down .375". I did retain the stock GTS baffle with the windage trays, BTW. I figure that Porsche is way smarter than me.....that actually didn't take much figuring.
gb
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 04-17-2007, 02:36 PM
  #52
Louie928
Louie928's Avatar
gb
I didn't see where the oil pickup support (two bolts) would go with the screen cover. I must have missed something. Nice looking screen setup. It should be effective.
Old 04-17-2007, 03:00 PM
  #53
V2Rocket
Rainman
V2Rocket's Avatar
What can you do to a 944?
Old 04-17-2007, 03:10 PM
  #54
V2Rocket
Rainman
V2Rocket's Avatar
Works for me lol
Think you could massage an 8V NA to 250HP?
Old 04-17-2007, 03:35 PM
  #55
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Greg has a 944 GTR racer sitting in a blow up bubble .....brand new never raced .That is the Transam car which made like 650 hp out of the 4 cylinder. Greg can "fix" anything !
Quick Reply: Hope for the poor old '85/'86 engines.
