Discussion of different Oil Control Solutions on 928s
Originally Posted by Sterling
I will dig them up and we should probably start a different thread on what people have tried that did & didn't work.
The oil is pressurized into the crank, and comes out from the sides of the main bearings, and the rods.
It then will fall down either straight into the pan, or onto the spinning crank, or off the crank onto various areas in the crank case.
I'm just kind of brain storming. There was an extensive thread that Kevin Johnson contributed several months ago.
The situation that Greg Brown's system is attacking is the flinging oil, and the pan's close proximity to the crank and rods, which is relatively close it seems.
Originally Posted by GregBBRD
It's hard to compare stuff without doing back to back testing. The problems I've had before with crank scrapers on a 928 is that the oil tends to get trapped on top of them on the 1-4 side and then gets into a continuous loop of trying to get by the scraper and being pushed back up towards the head. The 928 engine is somewhat unique in that the fact that the oil returning from the heads and camshafts runs down the sides of the block. I really didn't want to interfere with this oil return path, so I skipped the scrapers. The side mount pieces on the screens were designed to block the "sloshing" of the oil when the car goes around corners, while allowing the oil to return without resistance, to the pan.
Okay, so my earlier statement is wrong - the oil drain holes are not outboard of the crank (only) but are inboard as well.
You mean on the right side?
Then obviously more work was done for better draining past the framing?
I need to send mine back and get the update then.
Where is that deflector deflecting the oil to?
Obviously we all know that dry sump is the best, but many people just don't have the room or time to put it into use. This can be done on an installed engine (well, held up by 2x4s in the engine bay).
I think this (whatever Greg is doing with that screen) plus a large pan spacer is the best situation right now?
Its just "how low do you wanna go" with the pan.
Kevin mentioned to me that pan spacer is needed. I'm not sure if it must be added because there isn't space at all without it in stroker or if its just good practice from oil control point of view. This doesn't even matter as in my case as some kind of spacer is definitelly going in and it will be as thick as possible. I should have latest setup from Johnson.
I think starter is first part on line which will prevent really thick spacer to be used. Anyone have measurement how much oil pan can be dropped before starter becomes problem? I'm not so much worried about cross member under the engine as I think engine can be lifted up a little. At least when gear selectors front joint is changed to something little less tall. Though lifting block up could cause problems with 928Intl headers.
if you go with the aftermarket gear reduction starters you can add a 1/4 inch spacer... stock starter no spacer will fit.......
I suppose if you really wanted to be serious, you could make a new starter ring for the intermediate plate where it goes. I wonder how bg you could go before hitting something.
For all that work, a Dry sump is easier.
http://www.928motorsports.com/parts/hitorquestarter.php
What is difference in '78-86 and '87+ starters anyway?
I suspect there isn't room in bellhousing to go much bigger and its easiest just to change starter anyway.
When I get closer to installing my motor I'm going to spend a lot of time
trying to see what it would take to use a reverse rotation starter motor,
placed behind the flywheel (clock it 180°) Buy a used alum cover and start
carving it up. I think it would have to be more in the center of the down
pipes to be able to clear them. An aftermarket high torque starter is smaller,
the extra room gained there would be needed while moving the starter to
the 6:00 o'clock position. I don't see why this couldn't be accomplished with
the right resources ( Big 3 ?? !! ) A kit could be sold, modified alum, housing
starter & wire eextension $500 should more than cover the cost of the kit.
With the starter finally out of the way we could pickup an additional 1.5",
with a little rack sshuffling-- then build a proper oiling system.
The other part of the kit would have an exchange oil pan program, send them
yours and get one back that's been modified. It could be made deeper and
retain the oem pan rail area. No need for spacers. But go ahead and install
screens and baffles and whatever else that would be wanted.
Originally Posted by Vilhuer
I take you mean Carl & Co will get some more $$$ from me then?
I knew early years starter was mounted to bottom part instead of separate mount until '83 MY. I also knew about different mounts in '83-'86 and '87-'95. Looking at diagrams, wiring change from 3 to 2 points was done already in '85 MY. Despite all these changes PET gives one single starter part number for all MY's, '78-95. Strange if Carl's starter doesn't fit '87-95.
