Murf SuperShark - Supercharged US-Spec 1981 completed - fun way to spend a weekend.
#61
ya, don't tune down the fuel, turn UP the boost ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
those really are great #s for an 81tho, seeing as tho there isn't much 'modifications' out there for them! Im anxious to see the 10psi results!
#62
Administrator - "Tyson"
It's going to be a while since July is a very busy month for me. No more car wrenching (knock on wood.....) just a lot of driving and trips to Road America.
10psi with proper air / fuel and SS manfolds should exceed 350rwhp.
With 2:73 rear end 5-speed - this damn thing is a tire shredder
#63
Inventor
Git 'er dun!
#67
Originally Posted by toofast928
I the believe 4.5L is capable of 400 HP.
#68
Captain Obvious
Super User
Super User
impressive number! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Sounds like you running an FMU to controll fuel under boost. To bring the final pressure down you can switch out the spring and the diaphram for a smaller ration. This should bring down the fuel pressure under boost. Going with higher boost and having the FMU with the exisitng ration will make the problem even worst.
#70
We know how to dial in better air / fuel - This is the Corky Bell unit which is easier to adjust than the standard Vortech units (no need to swap out any disks). If we turned town the unit for less fuel up top, it was too lean down below. There are a few different ways to adjust this unit - it was getting late so we "settled" for what I posted here.
We set it at the happiest setting for overall driving. Sure I could have cranked out an even more impressive top end number playing with the timing and top end fuel pressure (or the old dry ice on the intercooler trick). It wouldn't have been realistic.
#71
Nice Numbers!
With the 2:73's that car must be a blast to drive.Might want to use a different ratio boost:fuel disc in the SFMU (if that is what you guys are using)-but you guys already know that.
Jim
Jim
#72
So now that I know everything is 100% good to go, I can go back, rethink the setup, go from there. I might try putting the vortech unit back in.
So this is not a SFMU like Tim has on his 88 - it's the sliver space ship looking FMU made by Corky Bell. They pretty much do the same thing, I think.
#73
Nice numbers Hacker !!
Bet the manifolds alone will help significantly to let 'er breeeaaath.
Gotta imagine that thing is rediculous when you shift --> 321.7 rwtq @ 3,915rpm, with 2:73 rear... 2nd gears done, clutch to 3rd a-n-n-d neckbrace please !! That's a serious E-ticket ride !!!
#74
hacker - think clearly now - Rick can ship you steel MSDS 2V headers for 425-450 - he discounts them for me the last two times.
#75
I have a spare one of those "spaceship"
FMUs..uninstalled, intended for boost referenced applications. Cartech/Begi. Email if interested, retailed around $250 I think.
