In tank fuel pump
In tank fuel pump
I had the infamous in-tank fuel pump failure problem about 5 years ago in my '90 GT. The short hose broke and which allowed the external tank pump to ingest some debris which jammed the pump. I got a 170 mile ride home in the cab of a flat bed car hauler. I replaced both pumps and vowed that would not happen to me again. About a year after that incident, I damaged the 2/6 rod bearing and took the car out of commission to fix it. I am now nearing the point of installing the engine. I needed to drain the old fuel out anyway so I figured I might as well check that in-tank pump again to see the condition of the hose. It was broken. The hose had the tensile strength and elasticity of refrigerated Monterey Jack Cheese. The pump is about 5 years old. The car hasn't been driven in 4 years, and the hose is broken. Not a good scene. Sure, the gas was old, but I doubt that old fuel had much to do with the hose disintegrating just sitting there. The original hose isn't compatible with whatever is added to gasoline. Maybe alcohol. Maybe something else.
Here is what I found.
https://rennlist.com/forums/attachme...d=104717&stc=1
Since the pump was near new, I decided to fix the hose rather than replace the whole pump with another cheese type hose. Here is the result.
https://rennlist.com/forums/attachme...d=104718&stc=1
The original hose was 12mm inside diameter. 1/2" fuel hose (0.465" ID), 1.25" long, from NAPA fits tightly over the hose barbs on the pump and the external screw fitting. It has to be better at withstanding fuel effects than the useless original stuff. The clamps are Oetiker brand, 7/8" (20/23mm) size P/N 584-2991. They are the same as the original clamps. Regular screw type clamps are too big in outside diameter to fit through the tank hole. I think the spring type clamps would work too, or even plastic tie wraps. All you need is to be sure the pump and screw fitting doesn't separate. You need a 36mm socket to get the pump out of the tank. The seal between the pump and the tank is a square cross section "O" ring. A regular R28 size "O" ring does work for a seal too and is a lot easier to find. I'll be putting a filter between the in-tank pump outlet and the external fuel pump inlet to insure no foreign matter can get into the external pump if the hose come apart.
The stock in-tank pump with poor quality hose is a stalled 928 just waiting for an unpleasant opportunity to happen. I'd suggest checking yours before summer driving season is here.
The hose is not the only part that's poor quality. If you saw the size of that pump's impeller you'd see the secondary pump is pretty worthless.
If I was up to doing it again, I'd delete the in-tank pump and install the strainer instead. You only need a couple gallons of gas for enough static head to prime the primary pump.
borland
90' S4, Slate Metallic
borland
borland
borland
I could swear Jim B gave me a good reason for the intank pump but I can't remember what it was. As I recall vapor lock may have had something to do with it but I'm not sure why. The only time I haven't driven a Shark home was because of the intank pump... on three different Sharks, all low milers. Let me restate, the only time I haven't driven a Shark home because of mechanical problems...
I am not sure why but as H stated the other day stale gas may be the problem.
Does the '87, '88 strainer assembly fit directly, without modifications, into the '89 in-tank pump access hole? It seems from this and other posts in the same vein, that the only risk to this retrograde modification is the possibility of a loss of some power when driving in high ambient temperatures with a low quantity of fuel in the tank. Against this, if the internal pump is retained, there is the risk of complete shutdown at any time - right?
The only time I've had to be hauled home was the in-tank pump and a bad coolant pump (separated plastic impeller).
Cottage Industry Sponsor
Here is an interesting related bit of information from Jörg Austen's book:
In MY 89, along with adding the in-tank pum, the fuel lines were switched to "Polyamid" materials. They might have forgotten to make that change on their new in-tank pump. The defect on mine was ciscovered at around 70k miles, even though it had not caused any trouble.
Well, I hope the newer fuel lines are less likely to cause engine fires...
My '88 has the in tank pump, but then, it's an 'euro': Believing this to be an inevitable failure, my long term plan has three paths ...
1) replace the hose as Louie has - but extend the hose to ~3"-6" along with the wires: why - I suspect that the 'wave' action of all that fuel wagging that pump back and forth on a puny 1" piece of hose is far more than the hose can take. Fatigue failure is the likely cause verses chemical degradation, as the bending radius of the assembly is pathetically short - so increase the working radius of the flexible coupling between the pump and flange. Also, a braided sheath would not hurt.
2) thread and/or braze a solid pipe coupling in place of the hose .... no flex!
3) Take the easy way out as Borland said .. use the screen/strainer: Our climate ( here) is quite temperate, so vapour lock is the least of my worries: it should be Sahara conditions or worse before cavitation would be an issue at the external pump.
Which to do ... probably won't know until I too get stranded: depends on how PO'd I am at the time ...
When first purchased my 79 had a big problem, it would start fine when cold, and run well, but would NEVER hot start, it was finally tracked down to the in tank fuel pump not running. Sure I live in a hot climate, but 928's are sold around the world so I guess they just did a fix that would apply anywhere.
Steve
Steve
You will be PO'd, the failure only happens after purchasing a full tank of gas
Last fall both of my pumps failed on my '89GT. As far as I can tell they were original and the car had 65k miles on it. I expected to find the hose on the intank pump broken but it was in perfect condition. I was thinking of going to the '87/'88 single pump setup with just the screen in the tank but ended up replacing both pumps. I called the distributor of the intank pump and they said it was rated at 5-6 psi. I purchased it from Autozone because they sold it for $120 and it has a lifetime warrenty which I fully expect to take advantage of at some point in time. It is the exact porsche part and even has the porsche part # cast into it. It came in a Master Parts box, their part #E8165H.
I have the strainer and dual external pumps... never a hint of vapor lock. IMHO the in-tank pump is only needed in the most extreme conditions, e.g. Saudi Arabia....
Under the Lift
Flexing it back and forth, checking the hose, I managed to get the hose end to pop off the outlet, and it would not go back on securely. So, this thread is helpful since Louie pointed out the crimps are available from Napa.
