DOOR Not Opening from outside
#33
This will be a long haul- I'd suggest we abort if inclement weather.
This is an inconvience,,not an emergency.
I greatly appreciate the help !
Best wishes for a Happt and Safe Holiday !!
Mike
Mike
#34
Under the Lift
We're going to play it by ear. If it's just little drizzly, I do have a tent we can put up that will keep us dry. Check in Monday morning.
#35
Sounds good.......
#37
Awww, come on... surely there's a way to make it work out. The forecast I saw calls for rain tapering off around midday. Jeez, maybe I should get Heinrich to regale you with stories of doing an engine swap outdoors in Seattle weather.
I do have an ulterior motive, as I plan to drop my fuel tank Tuesday or Wednesday to put in fresh vent hoses, grommets, etc. and it's too damn full at the moment -- a drive to Alamo is just what I need. Oh well, if it's off, I'll just have to carve up some twisties to lighten my fuel load.
#38
Under the Lift
I've got a canopy (er, called it a tent) that is 10x10 or so. It's been raining off and on tonight, rather heavy at times. If it isn't heavy, we should go for it. Check-in about 9:30. Night all.
#39
Under the Lift
I think we are on. Looks to be partly cloudy maybe with some showers here and there. I will get out the canopy, but hope we don't need it.
#41
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
SHARKS RULE !!!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Turns out the piece that connects the door handle to the opening mechanism is made of tin and frequently fails- called DEVEK, told them problem and they sent correct part- Jerry told me has several in his garage.
Once again- much thanks !!
Mike
#44
A successful surgery was performed on Mikes shark! The door lock motors were a bit more complicated than the OB I worked on before...but with some help from Georges website....all is well!
The patient is fully recovered and at home with its family! Only slightly wet from a bit of rain..
#45
Mike
It was nice to meet you,and refreshing to see a 928 door torn apart and have it not be mine!!!
Gerry
Gerry
