928 Forum 1978-1995
Sponsored by: 928 Specialists
Project 87-
Old 05-19-2024, 01:30 AM
  #166
rufrob
rufrob's Avatar
Pressed in the new bearing and reassembled the unit. The counter shaft took a bit of work mostly tuning the input shaft and rolling the transmission, then suddenly thunk,thunk, and it slid in. Next replace the output shaft seals, grease up the diff bearings install that unit light tap in the carriers and install the stub axles. Clean the housing and cover, install the cover.
I don't know yet how to install the lid with the springs and clasps.
Old 05-19-2024, 08:33 PM
  #167
rufrob
rufrob's Avatar
What is that spring called and what's it for?
I assume the tip goes into the spring. According to the WSM there should be shaft on the spring. Is this necessary?
Old 05-21-2024, 05:57 PM
  #168
rufrob
rufrob's Avatar
I worked on the 928 all day yesterday. Didn't have time for pictures between cleaning the transmission and rear subframe, installing and torquing everything the exhaust, rear brakes, wiring etc. the only screw up is the rear pinch bolt is not aligned for easy access. I was more focused on installing it with straps and jacks.
So now I need to run the engine ever so slightly which is not easy with the nose on the ground since there is no room to turn then engine from the top without removing the fans which involves loosing coolant.
Old 05-21-2024, 07:15 PM
  #169
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,582 Likes on 1,454 Posts
Connect the battery pull a 14 pin connector apart and touch the pin that’s closest to the front and closest to the right fender to the hot post and it will turn the engine
Old 05-21-2024, 08:45 PM
  #170
rufrob
rufrob's Avatar
Guess I should wire it so I can do it from under the car. It least this time i glued the clamp in place so it didn't slide off and disappear into the TT.
Old 05-21-2024, 09:31 PM
  #171
rufrob
rufrob's Avatar
I had the clean and apply anti seize to the brake pads. I thought the previous mechanic serviced them but now I know he didn't. So a brake fluid flush is also in order.
Old 05-23-2024, 08:11 AM
  #172
rufrob
rufrob's Avatar
Great success. No more bearing noise.
Just the V8 and injectors. Classic 928. Next challenge is the seats. I covered the badly damaged leather. Now it's either LSeat or try getting a local shop to only replace the damaged leather. The backs and head rests are fine. The centers and bolsters are dry.and cracked.
Old 05-24-2024, 12:51 AM
  #173
rufrob
rufrob's Avatar
Beginning to fall in love. Oh boy. Don't need any more ****ing cars!!
Old 05-27-2024, 02:03 AM
  #174
rufrob
rufrob's Avatar
Had to remove the rear spoiler again and pry on the mechanism to get it to open. Then i greased it up.
Old 05-29-2024, 07:08 PM
  #175
rufrob
rufrob's Avatar
Riddle me this Rennlisters.
A few days after finishing this job the engine wouldn't start. Found a blown FP fuse.
Now it starts but the idle is very low. It revs as usual and there is a bit of a vibration at around 2000 rpm.
Any suggestions?
Old 05-29-2024, 09:33 PM
  #176
Petza914
Petza914's Avatar
Received 6,722 Likes on 4,275 Posts
Any suggestions?
Vibration could be a cylinder not firing or plug wires connected improperly. Check that all the plug wires are solidly connected at both ends and make sure each wire is going to the correct cylinder.
Old 05-30-2024, 07:20 AM
  #177
rufrob
rufrob's Avatar
Found the problem on the 928. The left coil wire came off for some reason. Now 1/2 the plugs are flooded. I'll pull and clean them this weekend.
Old 05-30-2024, 08:13 AM
  #178
Petza914
Petza914's Avatar
Smell the dipstick. If it smells like gas, change the oil before proceeding - gas is a poor lubricant.
Old 06-01-2024, 05:57 AM
  #179
rufrob
rufrob's Avatar
I replaced the spark plugs with new Bosch ones. And still the same problem. No spark from the right coil. There is power at the coil. Any suggestions?
Old 06-10-2024, 11:57 PM
  #180
rufrob
rufrob's Avatar
Gee I wonder why the coil failed. Cracked and corroded. I could have sworn I cleaned its and it wasn't broken 3 months ago.
WTF happened!?
Swapped in a used coil and she is all better now.
Quick Reply: Project 87-
