Supercharger - dyno before & after comparison
Let's get right to the meat of the subject ---
FYI ---
1987 Porsche 928 S4
automatic transmission
70,400 miles
only mods -
Tim Murphy Supercharger Kit
RMB
The 'before run' had a spike
The spike was removed from 1 of the printed outputs
The SC runs were made with 7 pounds of boost
ALL dyno runs were made in 3rd
The 'before' & 'after' compairson
FYI ---
1987 Porsche 928 S4
70,400 miles
only mods -
RMB
Don,
Looks good. Only 7 psi boost at the dyno, was there any
problems?
I want to get mine on the dyno again when I get the boost
up to 8 psi. This weekend I'm taking off the s/c and i/c so
I can smog the car, then next weekend I'm planning on
putting on a new belt (thanks Tim). My before runs are
similar to yours (251-263 hp on 2 different dynos on 3 different
days).
problems?
days).
George -
No problems. I made an adjustment before the dyno run and didn't retension the SC belt enough.
The guys at the speed shop couldn't believe the HP increase!!!! Also, lots of compliments on the SC install.
I'm waiting to see your results.
Originally posted by Lagavulin
Excellent; welcome to the MURF928 32v SuperShark Club!
How are you liking all the extra power? (..stupid question, I know)
Thanks for the welcome...
I was thinking the reason the early s4 does so well supercharged is that it has lower compression than the late models. From 1990 on. The comp ratio was increased similar for the GT. Early cars have 9.4 versus 10 for the late cars and the GT.
Originally posted by atb
Don,
Did you not have the kick down disconnected? Where's the first half of the graph?
Don,
Here's what the graph looked like when (I guess that's what happened) the kick down switch activated.
I also have a dyno run (made on a Mustang Dyno) from the last Frenzy in Northern Virginia. I strongly considered using that run versus the run with the spike. I didn't want to mix runs from different dyno manufacturers - Mustang & DynoJet.
The Mustang dyno run is included for your viewing pleasure.
