Rear axle nut removal
I was reading with interest Dwayne’s “Torque Tube, Torque Converter Bearing Replacement Procedure” and noticed that he used a large breaker bar with a cheater pipe to break the rear axle nuts loose. In the case of the rear suspension already being out of the car, is it acceptable to use a high-torque impact wrench to break those nuts loose?
If your gun can provide the necessary torque I see no problem using such - the tightening torque is some 320 ft lbs [or whatever] so breaking that free may take quite a bit more torque to give.
my HF gun is rated at about 1100ft-lbs breakaway so we shall see. Thanks for the response!
please post result.
Basic Site Sponsor
Basic Site Sponsor
That's how we remove them, in the shop.
The axle nut is a one use item, BTW.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
HF rating is usually over-rated by 75%
Mine were on pretty snug and I had to use a 700 ft/lb wireless Dewalt impact to get them off. They came off pretty quick with that.
If all else fails you can heat the nut with a torch.
Just make sure your socket is strong enough to handle the abuse!
My pneumatic impact removed mine.
Hmmm...
If only there was some way to search for something....
Hmmm...
https://www.google.com/search?q=milw...hrome&ie=UTF-8
Yes, I'm a smart-a**.
On a more serious note, the big Milwaukee is a great piece of equipment. A friend has one and I've used it a few times.
The torque in the motor will twist the whole thing in my hand. Even holding it tight, it will go nearly a quarter turn. Lug nuts are off in an instant.
After trying to take the crank bolt off my car (no flywheel lock) with a pair of 4' breaker bars (one on the bolt and a chain wrench wrapped around the already damaged pulley), the impact took it off in about 2 seconds. Maybe a dozen 'hits'.
Hmmm...
