View Poll Results: For only a head gasket replacement only on a 16v and no other service work, would you
Voters: 59. You may not vote on this poll
Blown/Damaged Head Gasket?
#136
Couple things -
I think I have plastic covers somewhere. If you want them, and then if I can find them, they are yours for shipping.
The cam towers always leak. There is oil on them on this engine, however, because they were covered when I turned the engine over after I put oil in the spark plug holes. Mistake.
So they were dry before that. That said, its good insurance.
Plus, as I mentioned, I think you should use your 78/79 cams.
#137
If you do pull the cam towers Mr Brown makes improved cam tower gaskets. They would be worth it if they were expensive but they are stupid cheap.
#138
Couple things -
Yes, if you have unbroken plastic cam timing covers, I'll take them. The only good one I have is outer top left. I need and all the other ones, including inner left and right. Can you email me pictures of the ones you have?
Why do you say to reuse my cams? My plan was to pull the cam towers but not to remove the heads. Do you think there's an issue with the cams?
#139
Are these the good ones?
#140
Brendan,
#141
Interesting. I didn't know the regular 78/79 cams had higher lift and duration. I knew the Euros were different, but not the ROW versions. If that's the case, that might be worth doing now that you mention it. Do you happen to know the specs for the cams on both versions?
#142
Pulled the Clutch Pack today and washed more parts. Once I get the car back together and drive it with the OEM friction discs, I'll probably put this pair of SPEC friction discs up for sale so someone who needs more aggressive clutch grip can get a deal on them.
#143
https://rennlist.com/forums/928-foru...cam-specs.html
I'm guessing this setup is going to make a significant difference. I'll be moving the compression ratio from 8.5:1 to 9.3:1, increasing the displacement slightly from 4.5L to 4.7L and then if I use my '79 cams, combining those changes with increased lift and duration, this might turn out to be a decent HP & torque bump, especially with the supercharger, which I also recently upgraded. I'm getting kind of excited about this whole thing now, though I'm most excited about not having oil and power steering fluid all over my motor and the garage floor.
#144
Basic Site Sponsor
Basic Site Sponsor
Those will never leak, if you read and follow the instructions provided with them.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#145
No instructions included.
You have a PDF you can attach here or email to me at petza914@gmail.com.
Thanks.
#146
Basic Site Sponsor
Basic Site Sponsor
Looking forward to that.
Thanks.
Thanks.
I have instructions for every single thing I sell.
#147
I have instructions that have me dropping the steering rack to access the motor mount bolts, but those bolts look like they're just securing this bracket that is then secured to the motor by 4 bolts - 2 on each side.
Can I just undo these 4 bolts to free the motor and not mess with the sway bar or steering rack?
#148
To pull the engine, yes. That's how I removed and installed my S4 engine. Not sure on the 16 valve engines, but on the 32 valve after you remove the bell housing to engine bolts, you loosen the 2 transaxle mount bolts and slide it back about 1/2" or so and it gives you more room to get the engine loose from the bell housing and remove the engine.
#149
I don't recall exactly, but I think it may be difficult the get the engine high enough to clear the mounts if you leave them on the cross brace.
#150
