928 Forum 1978-1995
Sponsored by: 928 Specialists
Ben's 1982 928 S "restoration"
Old 04-02-2021, 02:09 PM
  #166
belgiumbarry
belgiumbarry's Avatar
now that you guys are talking about sailboats... this is my 50 feet, constructed myself ( and with prof's of course ) .
We were in the Med a few years and now stop sailing ... for sale . ( bought a motor boat )
Old 04-02-2021, 04:20 PM
  #167
Darklands
Darklands's Avatar
Received 1,192 Likes on 644 Posts
My boat is small enough for the place in the back of your yacht!
Old 04-02-2021, 08:07 PM
  #168
Kaplan69
Kaplan69's Avatar
I'm interested in what's going to happen with the center lock hubs...????? Ken
Old 04-03-2021, 09:44 AM
  #169
Ben006
Ben006's Avatar
Nice boats !
It's actually my father-in-law's boat, they took it out to the sea for the first time this week !
Hopefully we'll go out a few times this summer !
These are old F1 rear hubs, the rest of the car was completely destroyed I believe.
I'll use them to test my vapor-blasting setup and once clean and good looking I'll probably sell them because I have no room for them :/
My 928 will be in the shop by the end of the month !
Old 04-03-2021, 06:38 PM
  #170
ador117
ador117's Avatar
Originally Posted by Ben006
Hello !
Did a trackday yesterday, with the mini...
There was a 928 S4, very very fast ! Both in the corners and in the straight ! I can't wait to have mine on track !
You're doing a great job Ben! There is less and less Porsche 928 on the roads and even less on tracks... Looking forward cornering with you with your nice baby!!!
Raphaël
Old 04-21-2021, 03:51 AM
  #171
Ben006
Ben006's Avatar
I'm sure there are a lot of these broken around here !
This is my solution, I'm proud of it !
I also found the culprit of all of this 928's problems... check valve was completely clogged !
Cleaned the inside a bit...
I received the steel to make my mobile desk so I can 3D scan inside the shop easily !
Once done I'll start this one.... a bit more ambitious but very useful !
Today I take possession of my new delivery vehicle
I'll also use it on the track when the 928 can't go!
I received the 3D scanner !
It can scan idiots...
As well as cars !
I still have to practice but so far it's pretty good !
Today I'll move the lift to the shop when the rain stops !
Ben
Old 04-21-2021, 01:50 PM
  #172
Capt. Obvious
Capt. Obvious's Avatar
Received 1,515 Likes on 834 Posts
Great project! I just spent way too much of my work day reading this instead of working.
This thread makes me want a 928!
Old 04-21-2021, 03:02 PM
  #173
Ben006
Ben006's Avatar
That sounds like a good way to spend a day ^^
I got the lift in the shop !
Next step is getting rid of the red 928.
But before, I have to fix the blue gemballa 928 as there is a problem on the clutch hydraulic system... I hope it's not the master cylinder...
Old 05-05-2021, 10:54 AM
  #174
Ben006
Ben006's Avatar
Soooo
Here is a better application for the 3D scanner !
I was able to identify the aera where the mufflers would touch or not :
I also tried a 3" single tube exhaust :
I got a new set of wheels too !
I would love to use them but they are 16" :/
I'll show you later when they are clean !
LargeFarva (05-04-2023)
Old 05-05-2021, 11:46 AM
  #175
Shawn Stanford
Shawn Stanford's Avatar
I got a new set of wheels too ! I would love to use them but they are 16"
'82s were designed for 16" wheels! They give a nicer ride, too.
Old 05-05-2021, 12:21 PM
  #176
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
You should scan the fog/driving light bezels. For a Euro those are unobtainable here in the US
Old 05-05-2021, 12:35 PM
  #177
Ben006
Ben006's Avatar
But they won't fitthe big brakes, and my car will never ride nicely again 😂
Yes in europe either, i'm trying to find one for the red 928 and can't find any !
Shawn Stanford (05-05-2021)
Old 05-18-2021, 09:34 AM
  #178
Ben006
Ben006's Avatar
Sooooo,
Here are the wheels I got for 50bucks !
I love them, they are SERTA wheels, made in France in the 80's
But they are 16"... more on that later...
i received the S hatch... but it got damaged during transport...
Good news is that i should be able to bolt the S spoiler on my S4 hatch without much trouble. Just have to plug and paint the old S4 wing holes.
I finished my mobile desk... So i started 3D scanning a lot !
Et voila !
Today, with all the scans i did, I was able to establish a plan for the big brake kit !
I had a few options ! in stock I have : S4 spindles, S spindles, 997 calipers, 970 rear calipers.
i wanted to keep the discs under 330mm to fit the 17" cup1... but after hours of trying and fiddling, I couldn't fit the 997 calipers with the 330mm discs on neither of the spindles...
So I tried with 350mm cayenne discs... and I can make the calipers work on S spindles with 350mm discs !
After designed the adapter bracket, I printed one and tested it to confirm.
So... that's the route I'll take, 997 S front calipers in the front on S spindles, with Cayenne 350x32mm discs.
I have 5x130 aluminum hats, I will check if i can use them with 350x32 friction rings, but the cayenne discs are so much cheaper that it's a no brainer ot start with.
that means I have to sell the cup1 and Sarta wheels... but hey, more money for the rest of the car !
Cup1... rubbing...
panamera wheels, perfect !
Another solution would have been rear Panamera 970 calipers on the S4 spindles with 330 cayenne discs ! Looks like it should fit directly !
i'll order the discs and have all the adapters printed and check fitment one last time before starting production of the adapters. I don't think i'll make much, it doesn't seem like it will be a conversion a lot of people would do.
I have to order the stainless tubes for the exhaust too, with flatter mufflers.
Total cost, around 350€.
Old 05-19-2021, 03:20 PM
  #179
Ben006
Ben006's Avatar
And here is the rear !
Still Cayenne discs, 330x28
I'm not a fan of the first version, I'll refine it tomorrow.
I was confronted to a problem, how to thread 12mm lever straight by hand ?
Here was my solution :
It worked perfectly ! I don't even need to chamfer the shafts before starting, the tool catches straight right away and the thread is cut very fast !
My CNC router is almost finished too. But there is 3months of shipping...
Ben
Old 06-25-2021, 07:07 AM
  #180
Ben006
Ben006's Avatar
Oh boy you have stuff to catch up on !
I should get the machine soon !
The front brakes are validated, and the adapters are getting machined soon !
Perfectly centered.
The rear is validated too ! With 330mm cayenne discs... the hand brake is not working anymore, but it's a track car now, I don't care.
Et voilà :
I have to sell the CUP1 and the SERTA 3 pieces wheels too... I only keep the Panamera wheels. If anyone is interested in Europe ?
Quick Reply: Ben's 1982 928 S "restoration"
