928 Forum 1978-1995
Sponsored by: 928 Specialists
Piston Squirters
Old 01-27-2004, 04:48 PM
  #46
Chris
Chris's Avatar
Hey Tom, remember H drove my car that time to South Center .... wonder if he toasted my mains that evening ??
Chris
Old 01-27-2004, 04:51 PM
  #47
heinrich
928 Collector
heinrich's Avatar
We did drop a brand new Camaro in the dust that day .... ;-)
  #48
atb
atb's Avatar
Jim wrote:
Adam interesting thought ....perhaps they "wanted " to get the squirters out of the 5 speed cars first ?? maybe because they get driven more often at high RPM ?
Now don't be all trying to get in my good side here Jim, I still don't know if I forgive you for referring to Black/black S4 A/T's as "boring" in that other post. It took all the effort I could muster not to tear down the pin up I have of you lying across the hood of the very brown 928 being fed peeled grapes and being fanned by a palm leaf by all those scantily clad women.
Actually your point is exactly what I was thinking. Are we A/T drivers once again left holding the bag for some perceived mis-design by the Porsche engineers, only to show the superiority of the product in the long run?
Old 01-27-2004, 04:53 PM
  #49
heinrich
928 Collector
heinrich's Avatar
Dammit now you guys have Jim calling me H ... sheesh.
Old 01-27-2004, 04:57 PM
  #50
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Heinrich ........ I think " H " is better than what some people have been called !!
Old 01-27-2004, 05:01 PM
  #51
Lizard928
Lizard928's Avatar
Heinrich, I have to agree with Jim,
my nick is Lizard, yet people repeatedly cal me Liz, I think H is better than Heiny
  #52
heinrich
928 Collector
heinrich's Avatar
Very true Jim, I mean, look at poor Chris .... who'd want to bear the name "crank killer" like that ... shame shame .....
Old 01-27-2004, 05:02 PM
  #53
heinrich
928 Collector
heinrich's Avatar
Dammit Thin Lizzy, now you done called me a swear! Let's get on with the biz of oiling and such >:-|
Old 01-27-2004, 05:22 PM
  #54
Fastest928
Fastest928's Avatar
Dry sumping is good for additional hp too, about 4-7 per liter, so for a 6.5, you should have an additional 30-40 bhp. Hmm, maybe time to add dry sump to the next intake experiment...could be 650 rwhp....a tick over 800 crank!
Bob DeVores method of dry sumping is still the best way to do it cost effectively, Mark A has had good success using Bobs method....use the native pump for pressure and a two stage for scavenge...not terribly hard to do.for a race car
Marc
DEVEK
Old 01-27-2004, 05:41 PM
  #55
heinrich
928 Collector
heinrich's Avatar
OK. I think it's time we thought much more seroiusly about drysumps. As far as I can see, the most problematic is the cost of the scavenger pump(s). I believe they need to be electric, there's only so much you can run from a crank pulley ....
Old 01-27-2004, 06:16 PM
  #56
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
Originally posted by Jim bailey - 928 International
Yes H the 928 pump is rather robust and does run at high pressure the blow off relief is at about 8 Bar . The casting of the oil passages into the upper face of the lower cradle of the block was rather innovative when the 928 engine was designed and eliminated a lot of machining/ drilling seen in many engines .
Jim, The path of the squirters is interesting to me as they are in the lower cradle, is the path a "u" turn from the bearing journal?
From Marc T at Devek:
"...BTW, who do I have to ask if I add value to the 928 community or not? "
Well, don't waste your breath asking me........................
Old 01-27-2004, 07:40 PM
  #57
Gretch the squirters are in the main block in the webbing at the base of each cylinder each has a hole drilled down to the main bearing . The squirters each have a "check valve" and only squirt when there is enough pressure (similar to a CIS fuel injector in that respect ) . Each main bearing has two holes to feed two cylinders . The "boat tailing" done on my 911 engine case was to machine away the "top" of the webs at the bottom of each cylinder at an angle , theory being the flat spots on the webbing bounce the oil /air back toward the piston . There is no doubt in my mind that dry sump is far better but space and $$ make that one a little hard to do for a street 928 with A/C . I have wondered if a deeper oil pan slightly wider in the front sump might not help with some of the oiling issues especially with a couple trap doors to help hold oil near the pickup but that too is just a bandaid .
Old 01-27-2004, 10:52 PM
  #58
heinrich
928 Collector
heinrich's Avatar
I love this thread. I have a spare oilpan. Let's make some mods! Jim I know you have one, yes that's an oilpan not a footrest Brother ;-) So, I also have a spare pickup. Now, I'm going to look for an electrical oilpump, but in the interim I bet we could extend that sump outwards, leaving the narrow neck ....
Old 01-28-2004, 03:16 AM
  #59
Tony
Tony's Avatar
Yes H the 928 pump is rather robust and does run at high pressure the blow off relief is at about 8 Bar .......
just split mine apart today.
those are the channels in the bottom half of the block.
HTH
Old 01-28-2004, 07:40 AM
  #60
Lagavulin
Lagavulin's Avatar
Tony I'm glad you're on this board and share information like you do.
Quick Reply: Piston Squirters
