3D Printing 924 & 944 Parts - Development and Discussion
#212
I've seen that fold up one, and I've considered it. But I don't want to screw into the 951, nor have any adhesive that might harm the interior.
I'm trying to find something inventive to use. Now that 3D is a thing, I'm sure we can come up with something!
#213
If anyone is interested, I'll dig this model out and re-work it to address the couple minor issues I ran into (too thick and contacts dash when door closes, holder was designed for one specific cup). It'll require a decent sized printer, but I use it regularly and it has been great.
Earlier post:
https://rennlist.com/forums/924-931-...l#post13110814
Earlier post:
#214
#215
#216
He did increase the size some, seems he found online what the size a cup holder needs to be to hold the largest range of cups, and increased size 5%.
We go back to work Sunday night, so it will be Monday till I can do a test fitting on my 87.
I guess 2.75" is the magic number. He said it was at 2.68" in his software. I worry the size increase will affect how it attaches to the map holder, but we'll see Monday.
#217
Earlier post:
Earlier post:
#221
I might have to print that cup holder. Did the design files for the speaker/cup holder get lost?
I printed the one that replaces the ashtray. It's OK, but does get in the passenger's way. Also, make sure you remove it before moving the seat forward. Don't ask how I learned that.
I also printed a 'riser' for it, so that it can be reversed and the cup ends up centered over the console. That is better for the passenger but more i the way of shifting.
#222
#223
I can't say for the original design, but with the increase in size for a large range of cups, the blue one above does not fit in the map holder area of the door. (or any other area)
But to be honest, I think the map holder location is a good idea, just needs more design work. Might try to figure out something along those lines. Just seems like a good area.
#224
If you can take a pic of it in place, I can probably adjust the fit to be a bit better...
