Amps required to run car?
Rainman
Anybody know how much power (amps/watts) is required to run a 944 motor? I am looking at different alternators that are considerably smaller than the stock unit for mounting in a different location than stock - they are rated in the 45-60A range peak, 30-45 at idle. I don't have a fancy stereo, just the 4 4x6 speakers and sometimes 2 additional 6x9 - no subwoofers or anything big.
I do have the turbo front end and am adding the driving light option, but I have the harness to power the lights directly off the alternator rather than off the battery. Currently lights are all 55w but the headlights/driving lights may be bumped up to 100w in the future.
Stereo might be 200W (peak, I don't put it very high though), lights (incl. driving lights, at 55w each) would be 330W. 530W/12V = 44A...bigger lights would add another 180W or 15A to the load...so just sitting with the lights on and music is about 60A?
I want to keep air conditioning if possible, dunno how much power that draws but the compressor has a pretty small wire. The blower fan though probably draws some amps.
I know 924 guys put a smaller 65A alternator on their cars for some weight savings and they have the same power requirements as my car, minus fog/driving lights.
How much alternator should I get? Obviously the most A I can find in the smallest package, but what's the minimum?
I'm sure the loads could be calculated, but I sure wouldn't go too much under the stock output. I just assume the factory engineers used an alternator that is enough output, with some left over.
Hot night, stereo playing while sitting in traffic, both fans on, blower on high, etc...
What are you going to save? Like 1 pound? You don't race do you? So why do you care? You could empty your pockets of loose change and save more than the alternator swap.
Realistically i think you would need atleast 50 amps for a dedicated race car.. for a street car i think you need to look at something around 75-80 amps when you consider the blower for the HVAC, headlights / tail lights / side markers / brake lights, fuel pump, cooling fans..etc. You need to look at all the high load stuff on your car and consider how much current its going to pull in the event everything turns on at the same time..electrical motors can pull 3-5x the current they normally use when running on startup. The HVAC blower and cooling fans alone will be a very high draw when they turn on.
Bosch actually makes a lightweight 'race' alternator that puts out about 55amps and weighs about 7lbs. Honestly i think the weight is easier saved elsewhere, get a lightweight battery if you dont already have one. The Odyssey PC680 if i remember right cut nearly 20lbs off from a stock sized battery, if you want something with more CCA the larger one (PC925 i think?) will save around 12lbs. Or just do the Nissan Quest alternator which is marginally smaller / lighter and also puts out similar amperage.
Rainman
If I can't get it to work there then I'll remove the AC again, which will suck here in southern California right as summer arrives.
1 Post
I wonder if you could use the early model Nissan Quest alternator? Those are lighter and require a slight modification and seeing as how you are going the custom route anyway...
https://rennlist.com/forums/944-turb...eted-pics.html
Today I got
My Custom Title
My Custom Title
I've heard the AC takes 25A and the cooling fans take another 25, headlights another like 20 or something. I'm worried about once I fix my ac playing my sound system at night with ac on might overload the alternator
I think 60A is fine but to be sure you should also upgrade to a befier battery that could take the strain without relying as much on the alternator. Don't remove the a/c ,try the alternator first and if for some reason it doesn't work go from there.
According to the service manual it's not quite 4.25" but close ,it's 121mm .http://www.alternatorparts.com/cs130_sbpage1.htm
It's mounting point looks nice too,with a bit of luck and some triming it might fit the ps pump bracket.
PS:Take a look here http://www.powermasterperformance.co...hp?item_id=376
Rainman
You're right, I had forgotten how much smaller the early is than the late. Like I said though, not for weight savings necessarily (especially when adding a ~30lb supercharger) I intend to mount an alternator on the passenger side of the engine where the power steering pump came originally - for that location, the stock unit is simply too big.
