N-Tune
#541
I have no experience with swapping camshafts, but most people say that you will notice little to no difference in an NA application. I found the 944.105.155.09 camshaft difficult to find when I had to replace mine, so good luck sourcing one.
#542
My theory has to be seen only in conjunction with the MAF-Kit + 4° camshaft key (adv.) on a early 944.
The MAF-Kit + 4° camshaft key (adv.) generates a big improvement in engine performance and driveability.
Joshua's 944 NA is an early 944 (like mine) with the camshaft that closes the exhaust 3° before TDC. The only difference between the early and the late camshafts are the exhaust timings. So with the 4° Camshaft Key (adv.) the exhaust should (I hope to understand this thing) close instead of 3° now close 7° before TDC. So I assume, if you swapped for a late camshaft that closes the exhaust 4° later you could or rather should gain some extra hp at the upper revs. Provided you have an early 944 + 4° key (adv.) installed.
So far my theory.
But to make the whole thing complete, I ordered a coated MSDS header and I will give a late Camshaft in my early 944 a try.
So far my theory.
#543
But now I'm glad to know, that a late cam is better than nothing.
Thank you Joshua!
#544
Back to California Smog legality , It would be easy to swap the stock parts for testing but how about that offset key, will that affect smog?
#547
#551
Got Nothin'
My kit arrived this weekend, and I installed it Saturday.
Made a significant difference. The idle is much smoother, and acceleration seems peppier, even in 5th.
I also have the 4 degree offset key, but have not installed yet. I needed to get the car on the road, so I can work on my daily driver.
Very happy, worth the price, and the wait.
Great job Joshua!
Great job Joshua!
#552
Small Business Partner
Gad to hear you got the kit installed, and are happy with it!
The cam-key will make another good jump in hp/tq. The two (MAF & cam-key) really transform the cars power delivery.
