pulled air bag light today
im gonna be installing a 968 cs steering wheel ,so i took the advice of a few rennlisters and pulled the inst . panel ( did the much needed optical upgrade kit from 944online) and took out the air bag light bulb. tried it out , allgood. and BIG improvement on lighting , well worth it!
WILL MY FUEL SHUTOFF STILL BE ACTIVE? the other way is to snip wires #5and#7 from air bag computer. did not go that route.
also my new horn contact part# 928-652-104-00 is coming ( I was told clock spring delete) ...my concern is the face plate on the combo switch...will I have to modify it to accept different horn contact.... Thanks guys
hmmm, maybe this is why my car won't start with out jumping the fuel pump by removing the DME relay. I thought I was having alarm problems, but maybe it's the airbag computer. I just recently took the computer out, and that's when i started having the problems....
Sorry for hijacking your thread... as for your wheel install, I just got a non airbag turn signal module and it worked fine. One that looks like this
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
Can't understand why you guy have so much trouble installing a SC wheel on your 968.Beside the 2 hrs waiting time to( safely) disable the air bag it's an 1 1/2hrs DIY job ,no need for a none air bag turn signal ,no need to remove to remove the air bag ligth (just fool ) the air bag ligth with a 2 ohm resistor.The crescent shape (Brass) horn contact do come with all the accessories to install yout CS & there only on wire going to the horn.Once the resistor is intall you don't leave it inside the wheel ,the proper way is to shove it underneath the dash cover it with a rubber cap to make sure it's secure and tie-wrap it somewhere.Second pic & the six one is out of a 951 but will be the same for the 968.Iclude are the tool needed to do the job .
my combo switch doesnt have that brass L shaped thing on the right.
I got it all apart just fine ... waiting on parts to finish ...just wanted some affirmation that pulling the air bag warning light is a legitimate option . I wanted to pull the inst. cluster to upgrade the optical tunnels and go to LEDs anyway , SO NO PROBLEMO there
1990 944 s2 now air bag delete
Sorry never seen your second reply ,but now that the air bag ligth is out I don't really know if you should install the resistor but if I was you I will. One thing,resistor or not install make sure the the connection is properly tape & fasten underneath the dash -not in the wheel since there still power coming througt that connection.
Hey Thanks ernie for that info, I have a 91 944 cab, that Im rebuilding from a crash, its about 95% finish, I having trouble with the airbag light, I order a 944.618.217.01 module from dc, and they sent me three module all were bad, checking to see if you know anything about the module, Im about ready to cut one open to see what burn out inside the module, are just order another module from dc ?????
Airbag charge is gone inside of 10 minutes. No need to wait 2 hours to remove the airbag. That contact switch is from a 928. I added oe to both my 951's with momo wheels to get the horn to work.
