My 944 V8 LS2 made the cover...
#32
Hey Travis, nice going and the car looks really trick. Kudos to all involved.
#33
I was talking to a guy last year at Roebling Road who had an LT in his S2 and he said that the engine weighed 60# more thant the 3 liter. He was thinking about going to a LS engine block (aluminum?) that he said was actually 20# lighter than the S2 motor.
He said that the hardest part of the transplant is dealing with the relocation of the brake master cylinder...
#34
From what I hear, there is a weight distribution change, but not as much as you would think (75 lbs?). To put the power down, you'd need a LSD transaxle from a 951 or 968. I know a guy who tracks one in local events.
#35
#39
#40
Almost Addicted
From a quick perusal tonight, it looks like a great reference for a lot more than just getting the engine in there, it would be a good resource even if you aren't doing a conversion. Great piece of work.
#41
Alex- Well said, there is a ton of info about everything that is 944. When are you starting your swap?
#42
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
trackable ??
did raquel welch make 1 million years BC slightly more interesting ?
http://www.youtube.com/watch?v=_pADH...eature=related
try and name all the cars Tony destroys in the three video clips...
you ever seen the Motor Trend's War of the Worlds videos ? you can start with thems cars right here:
http://www.youtube.com/watch?v=c90zTpqkRDI
#45
0-60 with these cars isn't really a very good measurement, the problem is you will either spin tires through 3rd gear...grenade a ring and pinion...snap cv joints...etc
I've seen sub 7's on my car...with poor gearing...no 2nd gear synchros...in the rain (no kidding). So these things will move.
LS's will get mid 20's highway (without any massaging, just a stock engine) maybe even higher. My car gets 21 or 22...mostly because of having the wrong rockers installed. In the city it is a very different story, especially if you like to drive kinda hard...i expect around 16 city....an LS with a turbo rear would probably get closer to 20, but no promises.
