What Blinker Fluid to Use?
Since upgrading my suspension tailgaters on the track have noticed that my blinker fluid is more active.
A few questions for the experts here:
1. Should I increase the viscosity of the blinker fluid to counteract the extra G-forces that are now evident?
2. Is there an additive I can add to avoid excessive blinker fluid slosh?
3. Should I go synthetic or stay with dyno blinker fluid?
TIA Mike
TIA Mike
You definitely want a thinner blinker fluid in the winter time for proper blink frequency. Too thick of a fluid will cause longer blink frequency.
I am a fan of the synthetic blinker fluid, but don't know of any cures for fluid slosh other than keeping it topped off (blinker fluid tends to seep through seals slowly, causing the reservoir to get low)
DONT! DONT! DONT! use synthetic blinker fluid if you have been using dino blinker fluid all along. My friend did that and now his blinkers leak like crazy. I guess the synthetic fluid cleans out all the seals and causes leaks.
I also heard that the govmint banned the blinker fluid with the zinc stuff that older blinkers need.
My right high beam won't come on I aleady checked the bulb and the fuse, possibly needs a top up of high beam fluid? I like to use synthetic blinker fluid, I get more efficient blinking in cold weather.
Not Special
Could be that the fluid is too thick...what weight are you using?
Still plays with cars.
By all means use synthetic blinker fluid in a modern car. If 20 years old or more, use conventional fluid to avoid leaks as posted above. When choosing a high performance fluid, be sure to find one with a European additive package. The EPA has forced fluid producers to reduce the amount of zipDdoodah in new products. While some may claim that the reduced concentration of ZDDH is insignificant, too many experts have shown evidence of premature wear of important components in the blinker system.
Regards,
Regards,
