Selling my 944 S or trade 52,000 miles!
#64
Even Better
How did you hook up the horn?
Smaller is better since hitting of the thigh is an issue for people who use the track.
#65
If your turn signal does not work then here you go.
https://rennlist.com/forums/924-931-...eft-turns.html
#66
http://www.clarks-garage.com/shop-manual/ign-02.htm
There is only one reference sensor. Other one on your picture is not used.
At Clark's site you see that sensor also. 944S does not have speed sensor.
![](http://www.clarks-garage.com/graphics/speed-reference-sensor-retaining-bolts.jpg)
#67
![](http://joonas.pri.ee/gallery/albums/Porsche/Porsche_repairs/Cluch_jobsummer_2005/normal_IMG_6669.jpg)
Some pictures that I took when I replaced my 944S reference sensor holder
http://joonas.pri.ee/gallery/thumbnails-9-page-2.html
#69
#70
Hope the relay works for you. I picked up my first 944 NA that had a bad relay and paid 500 for the entire car because it wouldn't start. I popped in a new DME relay and boom fired right up.
#71
i dont know what i am going to do if the relay dont work...
dose anyone have a DME i can test the car with?
and the last thing i can do is replace the sensor..
if that dont work what the hell am gonna do...problem after problem..
#73
Did you check the sensor behind the cam gear housing...hall sensor I think it is? If that's broken you'll get no spark.
#74
#75
