Selling my 944 S or trade 52,000 miles!
Old 01-16-2009, 01:34 PM
  #46
jstand22
jstand22's Avatar
When you put the DME back on the metal frame the wire harness should be on top.
Old 01-16-2009, 01:47 PM
  #47
RED87944S
RED87944S's Avatar
alright,that dose help!...it should be facing to the front,i think,and the long corner goes on the top right side?
Old 01-16-2009, 02:22 PM
  #48
Jay W
Jay W's Avatar
Another idea. The 16 valve cars have a hall sensor right behind the upper timing belt pulley. Make sure that is bolted back in properly and the connector is plugged in correctly. That can probably cause spark problems as well.
Old 01-16-2009, 02:25 PM
  #49
RED87944S
RED87944S's Avatar
the plastic around that connector broke apart..so i am not sure which was it plugs in but i tried both sides..
Old 01-16-2009, 02:26 PM
  #50
RED87944S
RED87944S's Avatar
also where dose that cable with a metal peace and hole in it screw on the DME frame?
Old 01-16-2009, 07:21 PM
  #51
marcusw03
marcusw03's Avatar
If you need a spare DME i have a late model DME but it's not for an S. If it will work and you need something to check with I'll ship it to you but you gotta promise to ship it back.
Old 01-16-2009, 08:15 PM
  #52
gtroth
gtroth's Avatar
Originally Posted by RED87944S
i just pulled the sensors ,both had lot of oil on them for some reason..
Now I am confused. Only 1 sensor (ref and speed) on the 16Vs.
Originally Posted by StickShift
Doesn't the S model have the extra ignition module like the S2? If that has failed, you will get a no start condition also.
It is on the wheel well just under the expansion tank.
Yup. That's the ICM I was talking about.
Old 01-16-2009, 08:42 PM
  #53
RED87944S
RED87944S's Avatar
i dont know if that would work..i would send it back and ill pay shipping to me too..
Old 01-16-2009, 08:43 PM
  #54
RED87944S
RED87944S's Avatar
theres two..unless one of them is something else..
Old 01-16-2009, 08:45 PM
  #55
RED87944S
RED87944S's Avatar
i talked to the porsche people about what they did and this and that..at least they adjusted my belt,it was off by a bit..
can someone sell me a used DME relay for $15?
Old 01-16-2009, 08:49 PM
  #56
gtroth
gtroth's Avatar
It definitely will not work - need an S DME.
Old 01-16-2009, 08:55 PM
  #57
RED87944S
RED87944S's Avatar
these are the sensors..
Old 01-16-2009, 08:56 PM
  #58
RED87944S
RED87944S's Avatar
the top one look in good condition wen i pulled it out..the other one looked a little dark and felt ruff..
Old 01-16-2009, 09:02 PM
  #59
RED87944S
RED87944S's Avatar
Originally Posted by Kburke
Will it fit a 87 944 na?
saids it will,but i am not sure you want it..it is a little smaller then stock and gets in the way of seeing if the turn signals are on..u cant see the light flashing..and the turn signals stop turning off on most corners..
Old 01-16-2009, 09:06 PM
  #60
gtroth
gtroth's Avatar
--cant' see the 'bottom' one too well. Is it connected to a harness? Maybe it's just a plug to fill the whole? Cant' remember - haven't been in there for a while. But I am certain there is only one combination sensor used for the S that generates both signals (gets ref from a notch in the speed 'gear')
Quick Reply: Selling my 944 S or trade 52,000 miles!
