Aftermarket 944 Control arms. Retail pricing seems a bit off...
#122
....racing spring rates (~600 lb/in?), and a racing sway bar (welt?) set to full stiff setting. The highest load condition will be a combined braking and cornering load. I will assume a wide R-compound tire at threshold braking and 1.25 g cornering. Anyone have a 944 that exceeds that?
#123
I guess I could use 1000# springs and 1.5g cornering to be safe, but if that ends up causing me to make it too heavy I may dial it back. I will be using a safety factor in the design (not sure what factor to use yet). I have a feeling this design will be fatigue limited rather than static load.
I'll also try lower springs rates with the stiff sway bar, as that might cause even higher bending loads in the arms (I think looser springs will cause the higher sway bar forces).
#125
You are on the right track looking at the deflection. You will probably find that a design that satisfies deflection limits will also meet strength requirements. Don't forget to consider impact loads - potholes, kerbs, dropping it off the trailer, etc. You could probably use 3-5 g's as a basic check. Your highest steady state loads will occur on the outside wheel during combined cornering and braking due to weight transfer. I would start by modeling the existing part to figure out the best analysis methods and see how strong they are.
#126
Cory: Thanks, impact loads... very good point. Hard cornering and hard braking and you hit a pot hole or curb at the same time... that sounds like the worst case load to me.
#127
Chad, is anything coming about with your idea? Care to share with us yet?
#129
Seriously...I am still working through the feasibility. I have an idea, and I have been talking to various shops about it. Done properly, this stuff takes time. I am not rushing through this.
C.
C.
#130
Yes, but since we are both working towards the same goal (less costly aftermarket control arms), I think the more we share with each other, the less redundant or wasted effort there will be. I don't think there is much risk of anyone stealing your idea and running with it... this isn't exactly a high volume or high profit product. When you're ready to show it, if I see that you have a good design and are serious about putting it into production and selling it for a reasonable price, then maybe I won't waste my time pursuing the same end.
#132
The analysis will be based on loads that assume proper installation in the oem position and maintenance of the connecting points (no binding at the bushings, sway bar mount, or ball joint), racing spring rates (~600 lb/in?), and a racing sway bar (welt?) set to full stiff setting. The highest load condition will be a combined braking and cornering load. I will assume a wide R-compound tire at threshold braking and 1.25 g cornering. Anyone have a 944 that exceeds that?
I'm running 575# springs on a realtively light car (remember it's not just the spring rate but the ratio of car weight to spring rate that's critical) w/ MO30 sway and yes a fairly wide front tire (245's)
According to my traqmate my max G load was 1.4 right before I broke traction and went off...
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I routinely hit 1.2+ on a hot lap at VIR
#133
Wow! 1.4 sounds really high. Was that on a banked turn or something? I'll go ahead and assume 1.5 g max.
#134
Buckling is going to be the most likely failure mode, so I would concentrate on sizing them for this. Impact loading and bending are likely but by calculating mainly for buckling you'll be likely to meet the constraints of the other criteria as well.
#135
I must be weird, I dont consider $1k for the SFR arms overpriced at all ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
There are also Markus Blazack arms for less I think.
http://www.blaszakprecision.com/Control_Arms.html
