S2 Air Box Mod?
Old 12-27-2007, 09:47 PM
CarbonRevo
CarbonRevo's Avatar
Default S2 Air Box Mod?
So I got to thinking the other day about the 968 Air Box Mod. It gives a little improvment to the car, for hardly any work and the fact that it's free!
Has anyone done this on an S2? I mean, it's the same concept and idea. 4 holes, more airflow. If anything, wouldn't the S2 benefit more then the 968 considering the airflow to the S2 air box is more direct and shorter through the front bumper.
Pics of 968 air box mod can be seen here- https://rennlist.com/forums/showthre...968+airbox+mod
Old 12-27-2007, 09:57 PM
J Berk
J Berk's Avatar
hmmm....waiting to see what kind of response you get...may be interested as well!
Old 12-27-2007, 09:59 PM
CarbonRevo
CarbonRevo's Avatar
Well, I kind of already got impatient and modded mine!
Old 12-27-2007, 10:11 PM
J Berk
J Berk's Avatar
and?????
Old 12-27-2007, 10:15 PM
CarbonRevo
CarbonRevo's Avatar
Well, you see...the car is torn apart right now lol. However, she should be running next thursday or friday. God blessed OPRV O-rings are taking 15 days to get here, and that's all I'm waiting on!
I can get pictures later.
Old 12-27-2007, 11:39 PM
Chris Prack
Chris Prack's Avatar
It won't make any real difference. I have tried it on the dyno with marginal results.
Old 12-27-2007, 11:45 PM
Rich Sandor
Rich Sandor's Avatar
Did it to my 968 cuz it already had one small hole - it doesn't make a noticeable difference - just makes the car sounds louder from the engine bay.
Old 12-27-2007, 11:56 PM
luckett
luckett's Avatar
Location: San Francisco, CA Porsche: '92 968 Blk/Cashmere
snake oil. the inlet in the snorkel has the same area as the MAF inside diameter.
Old 12-27-2007, 11:59 PM
Chris Prack
If you eliminate the airbox on a 968 and keep the hot air off the filter you can get a gain. It's not a peak gain but you can get roughly 15 or so whp in the mid-range for about 2500 rpm or so. I have a dyno chart somewhere.
Old 12-28-2007, 01:26 AM
bleucamaro
bleucamaro's Avatar
my original airbox had a crack in the front side, so I broke it out and opened it up so there were 2 holes about 6" x 3". I didn't notice any difference in the seat of pants, and I've since replaced the broken box with another one I bought. Don't do it, not worth it, just makes your filter dirtier quicker and we know how easy those are to change.
Old 12-28-2007, 02:18 AM
billthe3
billthe3's Avatar
I think if you are simply trying to get more air into the engine your best bet is to simply ditch the box and get a cone filter.
Old 12-28-2007, 06:21 AM
adrian_jaye
adrian_jaye's Avatar
Default do a search !
Think this has been well discussed all over the place inclusing here.
I thought that the "take" on things is that the 968 air box is designed like it is for a reason, too get a certain amount of air into the system with little turbulance.
Same as the s2,
removing the airbox or putting a cone filter aint recomended prolly make things worse and at best is snake oil
search for "Am I just going to ruin my airbox?" on here
"yes. you will ruin your air filter box.
the intake is designed to be connected to the scoops above the radiator support because it's cooler air coming in from there. putting holes in the air filter box will let warm air in----not good at all. and that's just for the top side of the box.
Old 12-28-2007, 10:11 AM
Jfrahm
Jfrahm's Avatar
I've never understood why people think cone filters make their valves bigger. In most cases it seems to me that cone filter setups reduce the airbox volume, thus reducing the amount of filtered air available to rush into the engine without having to be dragged through the filter first. And of course the resonance effect is totally changed.
As for drilling holes in the airbox, as long as the inlet comfortably exceeds the size of the rest of the plumbing, intake valve area, etc. I doubt any good will come of it. Next time you are at the pool, try putting a 3" tip on the end of your snorkel and see if that helps you breathe easier.
-Joel.
Old 12-28-2007, 10:29 AM
SpeedBump
Happily Amused
SpeedBump's Avatar
I'm sure a few other 968 people will jump in but on the 968-
1) It sounds better
2) Some gain in HP proven on a few dynos
3) Lowered air temps (I'm not sure how it lowered them but I trust the **** engineer who did the testing)
Old 12-28-2007, 12:11 PM
PorscheDude1
On the Radar
PorscheDude1's Avatar
Some good information can be found here on the air box mod.
Even the naysayers eventually went with this modification after much debate here in the US and in europe. On a 968 the gains have been dyno proven.
http://www.968forums.com/index.php?showtopic=1094&hl=
Quick Reply: S2 Air Box Mod?
