Rear brakes dragging after disc/pad replacement...
Hey,
I just replaced the rotors and pads on the rear of my car and now they feel like they are dragging pretty bad...I don't know what the issue is. The inner pad on the drivers side was a b*tch to get in, but when it went in everything felt good...or so I thought. Any idea why they are sticking so bad? After about 5 mins of driving they were smoking a little.
-Darwin
-Darwin
-1988 944 Turbo S
SFR Stg 1 headers
LR MBC
Tial 38mm
SFR 3" cat-back w/ Borla XR-1
Vitesse chips
993 Cup II wheels
I guess it's not really bone stock anymore...
-1988 Volkswagen Fox Wagon GL
Too many upgrades to list!!
Somethin about '88
SFR Stg 1 headers
LR MBC
Tial 38mm
Vitesse chips
993 Cup II wheels
Somethin about '88
Hey Man
Have they been bedded in yet? New rotors and pads can be very tight. I was always surprised how far the pistons have to be pushed in to install the inner pad. There really isn't too much that can go wrong so I would try the high-speed bedding in before assuming something is wrong. They will get very, very hot but just follow the instructions and don't park it until they have cooled down properly. I've always used this method:
http://www.stoptech.com/tech_info/wp...contents.shtml
Well I pulled the new pads and put the old ones back in. The old ones had 50+% left so I'm not worried. It seems that the spring clips are bent on both the inside pads so its causing the pads to bind and not retract on one half. Do they sell just the springs anywhere or is this a "replace the caliper" type of situation?
-Darwin
-Darwin
It's actually corrosion behind the spring plates, unbolt them clear the corrosion and the issue should go away. The allen head screws holding in those plates are evil...they are locktited and must be heated prior to taking them out.
You could send them out to be rebuilt to a place like goldlinebrakes.com
Steve
Steve
When putting the calipers back on, you need to remember to put the spacer washers back. If you don't, the pads will drag on your rotors because the calipers will be in the wrong location. About 3 millimeters of difference IIRC
-Nick
-Nick
