Why is my car only making 116whp?
Old 09-21-2007, 02:16 AM
Tenacious_G
Tenacious_G's Avatar
At least you're not getting those hp numbers from a 951...
Old 09-21-2007, 02:22 AM
TRP951
TRP951's Avatar
well he actually is getting more, but only some people would know what we are talking about
Old 09-21-2007, 03:02 AM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
On a fresh-ish engine, I dyno'd at 123.6 on my 87 924S w/ an 88 engine...
Old 09-21-2007, 03:03 AM
Mighty Shilling
Wax On, Wax Off
115!!!!!
Old 09-21-2007, 03:45 AM
Gator_86_951
Spell Checker
Gator_86_951's Avatar
Originally Posted by Porschephile 924
115!!!!!
LOLERCOPTERBBQSAUCE
Old 09-21-2007, 09:36 AM
xsboost90
xsboost90's Avatar
i put down 124 w/ my 89 944.
Old 09-21-2007, 11:13 AM
J Silverman
J Silverman's Avatar
So that means my car is faster than a 951 then, right.
Do these cars really have 25%+ drivetrain losses? I know the transaxle/torque tub combo saps power but is it really that bad? A lot of the 944 spec guys are hitting 130 whp or so.
Old 09-21-2007, 11:49 AM
M758
M758's Avatar
Jason you are down on power. That is assuming these are dyno jet numbers.
You can try a couple things. IE spark plugs and having the injectors cleaned. You could even put in a proper test pipe, but in the end you just many need to rebuild the motor. Power down in that range is often a result of either cracked rings or slightly bent valves. Don't settle for this as normal.
Old 09-21-2007, 12:14 PM
J Silverman
Joe,
Spark plugs were changed about 5 months ago with the OEM bosch plugs. They still look ok. When I bought the car in may last year, I ran a can of BG 44k through the car when I bought it last may and in my experience that stuff does a pretty good job of cleaning out the fuel system.
Wouldnt a cracked ring or bent valve show up in the leakdown test? It was done after buying the car last year, so maybe I should do it again to see if this is something that has recently developed.
Old 09-21-2007, 12:47 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Could your ignition timing be retarded for some unknown reason?
Old 09-21-2007, 01:08 PM
spazegun2213
spazegun2213's Avatar
a little OT, but mongo that is the funniest avatar I've seen in a while!
Jason, you are in need of some work. I'd do a compression test just to be sure. I'd also look at the timing to see if its right.
Old 09-21-2007, 02:14 PM
J Silverman
Mongo- Ill have to check on that. The cam timing should be ok as the belt was replaced at the beginning of the year, and retensioned after 2000 miles. I just got off the phone with a friend that works at a shop so I think Im gonna redo the leakdown test and also test compression while im there. How would the ignition timing retard? I thought the DME controlled the ignition so... but I guess I can try to borrow a timing light and verify.
edit- Ok here is the dyno, still trying to get the AF ratio, but I think the shop erased them.
Old 09-21-2007, 04:12 PM
944CS
944CS's Avatar
What type of muffler are you using? If it is a straight through type, you could be running very lean, causing the low power. I have first hand experience with this. I wanted to see what my car sounded like with a test pipe and no muffler (stock chip also). I went for a drive, and noticed the car went very lean on full throttle (according to my wide band, I forget the exact values however). It felt like I was driving a 1.8L that made 100hp tops.
Old 09-21-2007, 04:44 PM
lvkid76
lvkid76's Avatar
Its different coming from my sti hearing people talk about 300 to 400 hp to 100 to 150 hp.. lolll.....
Im not in kansas anymore.
Old 09-21-2007, 05:00 PM
J Silverman
Exhaust is OEM from the manifold to the exhaust tip. The only thing Ive done is "adjusting" the cat with a jack handle when it got clogged. When that happened the car wouldnt rev over 5k, and eventually it just died on me. It had a piece of catalyst big enough to clog the pipe break off! I dont think this is the issue but I was going to drop the exhaust tomorrow and see if I can clean the cat out a little more.
Quick Reply: Why is my car only making 116whp?
