Why is my car only making 116whp?
Old 09-20-2007, 09:43 PM
J Silverman
J Silverman's Avatar
Default Why is my car only making 116whp?
Ive been trying to figure this out for a while now. I had the dyno sheets but they got rained on and they were thrown away so I dont know the A/F. Im trying to get another copy of them though. Anyways the car (88 924S) only made 116 whp, and similar torque. The motor tested 3% leakdown on cyl 1 and 3 and 7% on 2 and 4 so I figured the motor was healthy when I bought the car. The cat has been gutted so I dont think that the exhaust is clogged, anyone have any ideas?
Old 09-20-2007, 09:55 PM
bjzorn
Canadian Yankee
bjzorn's Avatar
Was in Actual HP or was it corrected? on the dyno sheets?
Old 09-20-2007, 10:02 PM
J Silverman
SAE corrected. I didnt get the data files to see actual hp, but even using SAE correction it shoudl be 125+ to the wheels. A lot of dynos Ive seen are in the 130hp range.
Old 09-20-2007, 10:10 PM
bjzorn
Canadian Yankee
bjzorn's Avatar
Yeah your right I thought it may have been Actual but if its corrected hmmm.....
Old 09-20-2007, 10:31 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,225 Likes on 1,254 Posts
What is the rated crank HP on that motor?
Old 09-20-2007, 10:37 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Get a compression test and post your results
Old 09-20-2007, 10:53 PM
bjzorn
Canadian Yankee
bjzorn's Avatar
Same as the 8V 944 so 140 or so.
Old 09-20-2007, 10:56 PM
V2Rocket
Rainman
V2Rocket's Avatar
Might just be old...out of the box they probably hit 130 to the wheels so it might just be tired and need a rebuild...
see topgear where they have an 80HP lLambo orignally rated in the 70s for over 200.
Old 09-20-2007, 11:12 PM
J Silverman
I didnt do a compression test because the leakdown numbers were so good. If the car isnt loosing air on leakdown what info would a compression test provide?
Ill see if I can get someone to lend me a tester, or maybe Ill pay a visit to harbor freight.
The 88 motor was rated at 158bhp.
Old 09-20-2007, 11:32 PM
V2Rocket
Rainman
V2Rocket's Avatar
wasnt the 924S engine slightly detuned?
Old 09-20-2007, 11:36 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
nope. and like the 944, the 1988 924S engine had higher compression.
Old 09-21-2007, 12:05 AM
V2Rocket
Rainman
V2Rocket's Avatar
so what was the point of selling both?
Old 09-21-2007, 12:11 AM
Techno Duck
Techno Duck's Avatar
By the mid to late 80's the 944 wasnt so 'entry level' anymore. Porsche wanted another car to be 'attainable' and had it priced around $20k. It basically an early 944 in the slimmer 924 fenders..and a mix match of early and late offset suspension parts.
The '88 924S is pretty sought after by people into competition motor sport due to its lower weight and higher compression engine.
Old 09-21-2007, 01:22 AM
Mongo
Fuse 24 Assassin
Mongo's Avatar
My bad.
Are you running lean or rich? Those leakdown numbers are not bad.
Old 09-21-2007, 02:13 AM
saxman
saxman's Avatar
A 158bhp rwd car probably wouldn't dyno at a whole lot more than 120 whp from the factory anyway.
Quick Reply: Why is my car only making 116whp?
