Making good NA hp- even possible?
#91
Almost Addicted
I get your point- its just that almost every time someone brings the issue up, they get shot down immediately. We need to let people experiment and tweak their cars.
#92
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
The problem is in reality, there are people that don't intend to spend lots of money with this experimentation. This results in threads likes this being created and shot down.
Improving upon a Porsche IS NOT EASY, whether it's a 912, 944, 993 or a 997 Turbo. There are constraints on all cars that limit factors of modification. The guys that built these cars are engineers, not just someone that got hired to design and build cars right out of high school.
#93
Actually, I've read numerous books related to Bosch L and LH Jetronic fuel injection systems. Both of these systems are designed to run lean condition toward the higher RPM for emissions purposes. A chip will help, but at the same time, a properly programmed chip will override the lean condition and stabilize the A/F ratios, MAKING MORE POWER.
Now if the Motronic on the 944 is so praised, why aren't there more people taking advantage of this out there and creating 'super PROMs' that yield 'significant' gains? Perhaps it's because the L-Jet still incorporates an AIR FLOW METER.... That is the weakest link.
Now in the case of Bosch LH, you have a Mass-Air Flow Sensor. Companies like Autothority have created a PROM for 928's that maximizes the LH system and utilizes the MAF better. The dyno charts actually prove a gain in HP rather than what I have seen on any 944.
Really? Motronic is not the best? You were praising it above. It's easier to make more power out of a Turbocharged car running CIS injection than it is to make power on an L-Jet. BTW...How much went into that engine to make 200+ HP? I'm not saying it's not possible. I was saying IT WILL NOT BE CHEAP Is it streetable with that power? What fuel does it take? You can do a 13.5:1 compression NA 944 motor but it will never run anything less than 94 octane again unless it has ignition timing retard and knock sensors.
http://www.amazon.com/Bosch-Fuel-Inj...d_i=0837603005
If i recall correctly, this book states the AFM is restrictive by .5 MILLIBAR. Milli means 10 to the minus 3 power. That is .0441 psi. You lose aprrox. twice that much air pressure just going 1000 feet above sea level.
If the motronic is so praised, why aren't there magic chips out there you ask? How much hp do you expect to gain with a tune when the engine in question has 9.5:1 compression, 8 valves, and a cam with no overlap? The Motronic will do everything you need it to do. Its not the Motronics fault that the stock engine limits volumetric efficiency and the capacity to produce a high bmep.
My disclaimer was put in to say that I am not saying it is the best, thus my use of the words "I am not saying the Motronic is THE BEST". Where did you get the idea that it's easier to make power out of a Turbo with CIS than it is with Bosch LH?
To build the motor I am talking about was over 20 grand in parts/outsourced machine work alone. Earlier in this thread I said it would cost over $20 grand, I never said anything about it being cheap, or easy. If it was easy, everyone could do it. Yes, it is daily driven. It does not idle like a stock car however, that is something you cannot get around with a car that A. makes power at as high an rpm as this car does and B. does not have variable valve timing. It runs on east coast 93 octane.
I hope I was clear with everything. I am not trying to be an ***, it's just some of the things you are saying are completely, just, wrong. But I do not blame you for being skeptical.
DDP, would love to know the CR and projected life span of that motor. Also, is it running above 10K?
Tifo, I understand where you are coming from. But I don't think this car will ever be dynoed so it can prove to everyone here it really is a 200+ hp 8 valve n/a. If you watch this video, you can see the acceleration comparison with a mostly stock 944:
http://www.youtube.com/watch?v=T1ujPOL0jUk
#94
Fuse 24 Assassin
Fuse 24 Assassin
944CS, I can understand your defense on Bosch L-Jetronic. I have a book called Tuning and Modify Bosch Fuel Injection that follows the same guidelines as that book. However, it's slightly compressed down into a $23 book found in Borders.
What measuresments are you talking about up there? Are those for the 944? If you look at the intake pipe that it's going into, you can see that the amount of air flowing into that small square opening does not provide effective volume in the boot. (I think it's 3" for the factory intake boot) With an MAF, there is no restriction from a barn door.
You can do amazing things to a 944 engine for $20k. I would go that route if I was very much in love with the car. However, I would rather put that money into a house or a Boxster that has 200+ HP already
#95
I don't understand what you mean, that hole supports well over 200 hp. Especially on an N/A car, you want to keep things as small as will be sufficient to keep your air velocity up - this is true not just for the head.
#96
Almost Addicted
#97
Fuse 24 Assassin
Fuse 24 Assassin
If opportunity knocked and I had a budget dedicated to the 944, I'd take that ITB setup I'm making and use TEC-3 engine management to get that sucker to really sing.
#99
Billowing in the Wind
talking VERY high RPMs. I wish I knew all the details, but there are certainly formula-type motors in the 2.5 litre range cranking out 500hp+...in the 10,000 RPM range!
If you can keep your motor from Porsche disintegrating, you could probably do it.
But remember, there's a whole lotta gears between 0 and 10,000 RPM.
#101
Fuse 24 Assassin
Fuse 24 Assassin
Why make anything in that motor lightweight? You have almost a 2500cc engine with a 100mm bore and almost an 80mm stroke. You will not get far up the rev range with those specs. In fact making something lightweight with that bore and trying to squeeze 8500+ RPM out of it is asking for catastrophic failure.
#102
see post #80...I will tell you that is not 7000, or even 8000 rpm....that motor has been together going on a year, numerous track days on it, daily driven. Mongo you need to get out of rennlist world, its much nicer out here.
#103
here is a copy of an emial Jon Milledge wrote me about 3 years ago. I asked him if he could make me a head/cam combo that made 200 hp with stock compression ratio. I had a low mileage engine that I did not want to rip into.
Chris,
You need to lower your expectations. The best stock type engine I have
ever built made 196bhp with 11.3/1 compression, 1mm overbore, flowing 5
different stock 85/2 on cylinder heads to find the best one with just
the right core shift in the casting, hours and hours of dyno time
developing headers, a digital programable ignition system and much
more. I tried many different camshafts, mine and most of my
competitors. This engine used a 1988 engine as a core.
What can you achieve? I would first want to know why you want to
retain the stock compression ratio. This engine is not knock sensitive
and can safely run over 10.5/1 compression ratio on 92-93 pump octane
gasoline with no problems. This is also prime in improving fuel
mileage and power. With a proper valve job and compression increase,
a camshaft change, a K&N air filter in the stock box, and an exhaust
system upgrade, you can make 175 bhp.
Jon
Chris,
Jon
#104
Fuse 24 Assassin
Fuse 24 Assassin
I said what I had said up there because I have seen people that hot-rod engines to large bore and high rpm machines only to realize they put money into something that blew up in hours or within 10,000-20,000 miles after the break-in period when they are wound up to the max.
Get out of the Rennlist world? Sure why not! Seeing that only the good people here respond with real information to my threads on here, while the other 95% that respond to them spam it up with misinformation and hijacks.....then again I am in the 944 FORUM.
#105
Fuse 24 Assassin
Fuse 24 Assassin
Chris,
Jon
Chris,
Jon
Did you do it? How much was he going to charge? Was it really worth putting 200 HP in a car where the performance would then compromise the reliability of the drivetrain...namely the R&P?
Milledge sells an ITB setup for almost $3,000 and has NO DYNO SHEET on his website with that setup on a stock NA motor. See this is where the argument starts on whether or not exceeding your car's market value 100%-200% is really worth it...especially if you're driving it on the street. Insurance companies will not care if that thing gets wrecked and will still give you low-bluebook if you don't bust your *** giving them receipts for everything to get at least some of your money back.
Racing? sure why not! At least you can stretch your car's performance to the limit.....now reliability yet comes into question....
