Another exhaust sound data point
#721
to JCR,
i went to an audio acustics shop who already worked using sound deading to some exotic cars especially with GT3s, he just suggested to deadn the engine upper cover metal and its sorroundings a first phase using just hushmat and my finding for my GT4 718 were:
- the drone with oem exhaust from 2-2.5k is almost gone from noticiable - hardly noticeable
- the click sounds from the engine bay is hardly there when i was idling between traffic lights
- this is surely agreat suggested mod for those whos doing any exhaust setups for our GT and for those who’s paranoid from any drone in it.
my other take as i did this already it made the car quiter (near same when it had quite mode) but the positive it made the crappy bose system to be from bad - normal/acceptable
also done a must have mod relocating the annoyed passengers leg fire extinguisher and man it made a worthy change.
Relocated the fire extinguisher with just strong velcro it its a 100% perfect
#722
What kind of HushMat did you use?
#723
Assuming the 718 Spyder and the 981 Spyder are similar, this video shows that there is a thick piece of foam rubber on top of the metal engine cover. So did you add a HushMat to the underside of the metal cover?
I checked my car. I have the same foam rubber mat, but it's interesting that the part is not show here:
https://www.porscheparts.us/v-2016-p...trim-rear-body
#724
it was about 3.5 sheets of Hushamat.
weight of the sheet after peeling it is easily less than 400 grams but i was using my hand vs my iphone on the other hand so i even think maybe - 300g a sheet. Its well worth it if you drive it in the street for sure
#725
https://www.youtube.com/watch?v=t8LjxiNwXzs
#726
#727
#729
Thanks! Interesting. Do you know if the GT4 has the thick rubber padding on top of the metal plate like the Spyder does? Perhaps that’s only stock on the Spyder. I’d be concerned that adding another 1/4 - 1/2” would make it more difficult to Close the roof on the Spyder. It already seems pretty tight.
Actually, I see that Dynamat is only 1/8” thick. That should surely fit. But I’m still really curious if the GT4 comes stock with the thick rubber mat that the Spyder has. It seems like that by itself should be quite effective at muffling.
#730
Just a note... I got the dreaded BLACK FLAG at the track last week. Stock 718 2020 Spyder with the traps open....92.4 db's. Too loud! Max permitted is 92db.
It passes with the traps closed. Most of the tracks are enforcing the noise limits.
#731
Thank you alwaysdriving. They make other products with foam on them as well, but this is the aluminum with the viscoelastic layer to dampen the metal. Much like dynamat or similar products. Putting some of this under the trunk floor may also help with noise and chasis vibrations thus lowering drone.
#732
I now have 510 miles on my car! I’m driving with no place to go just because I love driving it. I’m amazed at how much better the sound is now with only 500 miles. I was really worried when I first drove it because it drowned and whined like crazy, but the drone is 90% gone now. I can’t believe the difference. Can’t wait to fully break it in.
UncleDude (10-14-2020)
#733
I am just over 1500 miles, never really noticed any drone, but did notice that the sound has changed since the very early days, much deeper now.
The following 2 users liked this post by Sausage416:
964C4 (03-24-2022),
Rennolazine (09-26-2020)
#735
Would you call it a very loud system? Thanks, and enjoy.
