GT4 RS Driving Impressions
#961
I'll add my 2 cents here....on bumpy tracks the rear has a hard time putting down the power. You will see the TC light come ON.
I added the DSC and that helped. Also 19" wheels and stickier tires...but still have a section that is robbing me 1 sec for sure. Turning OFF TC/ESC could help a bit but this is an area that's very risky to loose traction.
I could see how a nice set of 3-way dampers could tame this bounciness and improve times.
#962
I was on VERY bumpy back roads over the weekend, no issues putting the power down (the car has a DSC controller). I suspect what you folks are describing is esc/traction control cutting power to the rear when the suspension is unsettled - as it should be doing.
#963
Exactly...because the rear suspension can't cope with track imperfections at speed.
Road is very different from track...Try going +70 mph in a turn while feeding power and hitting some bumps. The front takes them OK but the rear is being fed power and can't cope....thus loosing traction as the tires are not planted on the surface.
The DSC did helped a lot but there's still some rebound/compression control that might be out of the DSC + OEM PASM scope of control.
Not complaining just mentioning that it's there when you are not in glass-smooth tracks
#964
From: Mid-Atlantic (on land, not in the middle of the ocean)
The car has plenty of power and is set up stiff for the track. Should not be a surprise that it can't put down all the power on a bumpy surface. McLaren's have better ride quality, but Porsches still generally produce faster lap times if the tires and power are equalized (and Porsches generally have less power than McLarens).
#965
Imo the stock 4RS suspension is fine for good pavements. But the few times I found myself on broken pavements it was nerve-wrecking. And I certainly would not drive it in Boston or NYC. Plus, all stiffly spring cars I've owned get scary when they hit bumps at deep throttle and high speed. That's when you wish you are in a GR Corolla.
As to the GTS 4.0, talk about a car that needs Ohlins. The stock setup is so underdamped, with so much body motion, it is undrivable with S-PASM in std, and barely acceptable in firm.
How people can have such polar opposite reactions to the same cars is kinda "shocking."
Manifold (05-13-2024)
#966
I believe the reason for the polar opposite handling feedback boils down to the myriad of variables involved, which can have significant impact. Tarmac conditions, Temperatures, Driving style/ability, Tire pressure, Tires (PSC2 vs. PS4), wheels (mag vs. non-mag), brakes (cast-iron vs PCCB), and PSM/TC enabled/disabled, which can be very intrusive and make the handling behave non-ideally. I also suspect PAG updated PASM software along the production line, as anecdotal evidence suggests MY23 seem to complain more than the MY24 crowd. Albeit, you would think the PASM update would be part of a broad TSB effort.
Eric5280 (05-13-2024)
#967
I also wonder how the exhaust (stock or aftermarket) is impacting rear shock performance (better or worse) especially in boundary/heat soak conditions. My Panigale rear shock would saturate from exhaust heat after 5-6 laps and pump like a bronco on corner exit, so bad so that I would have to short shift just to stay on the bike.
#968
Good ride quality lol
lol it's crap really, maybe good vs a 991.2 RS or 992 GT3 but this rear end on bigger bumps flings the car in the air. ok not quite that bad but never had a car as bad as this on bigger bumps at the rear in my life., The rebound rear setting from Porsche is totally off.
went for an over take at the weekend, back jumps about cannot get power down , did not really even see a bump.
Ride over all is ok, but the car hates big bumps where my 4.0 GTS would eat them alive and be down the street, on UK tracks here (the bumpy ones a 4RS cannot keep with a stock 718 down a straight ! smooth no issue bumps the 4RS cannot cope at all and this is with much lower pressure, if you let them get up to say 35psi at the rear the cars even worst to a point I think it would throw you off the road.
Don't listen to the fan bois, they will defend Porsche at all costs AND/OR live where the pavement is smooth.
You speak the truth. I had the same issues with my stock GT4. Bigger bumps on the freeway at 80MPH would send the rear of the car up in the air and the rebound to its stops. Totally horrible and unacceptable damping profile. Add to that the pogo stick effect you get on the front axle, then when loaded up in corner and you hit a bump or dip mid-corner, the front and rear just felt out of sync with each other. On a smooth road though it was magic.
MCS 2-way remote dampers and better spring rates made it a totally different car and one that could actually keep up and surpass your average Camry on less than good pavement. All of those bad traits were now gone. So, that is the good news, you can get it there with good aftermarket dampers.
BMW does the same thing with their cars though, always undamped on the rebound stroke and over damped on compression. I think they are set up to be great on Euro smooth roads, not bumpy US roads. For US roads you really have to have stellar rebound control.
#969
The word is out. Porsche makes bad cars, especially the GT cars. Their engineers suck. Nobody will want the cars now, demand and prices are poised to plummet.
#970
#971
#972
#973
Friendly reminder on what happens when you decide you want to go with a high end passive suspension setup. I spent 11K all in on a high end JRZ 3 way system on my 997.2RS because I was unhappy with ride quality and PASM at the time. I also tried DSC on the car before trying the JRZ system. I can honestly say the difference in both systems was much smaller than you may think. Based on what I learned from using both I personally think the value is in the DSC system. If you asked me to quantify I'd say the DSC controller made the car 20% more comfortable and the full JRZ system about 30% better. Things people forget about: Modifications to the car (mounting canisters brackets etc.) along with new sounds and creeks, multiple alignment costs, learning to adjust the rebound and compression for street and track, time without the car and do you want to do all this to new car and mess with your overall value? I will never do it again on a street car. On a race car if you have support and the knowledge to go with it 100%. My 2 cents.
Valid opinion, but just that.
I enjoyed the process of learning about compression, rebound, canister pressure, and tire pressure and how they all interact with each other and what each can and can't do. I spent more than a year trying different combos and learned a lot along the way. I am now at a point that I know exactly what to change and by how much to achieve a certain result.
I have no added noises or creaks (if you have those, then your installer messed up). I will concede on the alignments though, they can get expensive , but once you know where you want to be and what you want to achieve, it's a set and leave it.
While you only experienced a marginal difference, I experienced the total opposite, the difference was huge, not incremental. That will vary with chassis and how well the OEM set-up is, so that is a moving target. I have a few settings profiles I will move to depending on the weather (rain) and what I plan to do with the car. Takes 3 mins to change with the clicker dials.
I submit that is it is even more important on a street car (the cavat being if you are a professional race car driver and do it for a living) to have good damping as the roads are not as smooth and not maintained in the same way a track would be.
