718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
OEM Navigation Retrofit DIY
Old 02-02-2023, 12:09 PM
  #346
xterm
xterm's Avatar
Sorry my bad. It’sMH12_ER_POG11_P5176
AIO only lists MH12_US_* versions.
It’s listed here:
https://rennlist.com/forums/general-...ctivation.html
seems like I have to follow the hard way.
Originally Posted by Westcoast
@xterm What is the version of your PCM?, if it is not as shown in the picture in post #1 then I don't think AIO will work for you, but you still might be able to manually update the firmware if the appropriate versions/patches are on MIB.
Old 02-02-2023, 12:44 PM
  #347
Z06jerry
Z06jerry's Avatar
Originally Posted by Lucifer
People with NA '22 Spyder, did your car come with the antenna?
I have a GTS4 but I'm pretty sure Spyder's had to have CarPlay from factory for the Antenna to be present.
The following 2 users liked this post by Z06jerry:
718socal (02-02-2023), santiago660 (02-02-2023)
Old 02-02-2023, 12:49 PM
  #348
Westcoast
Westcoast's Avatar
Received 4,696 Likes on 2,733 Posts
It’s listed here:
That's what I thought, the "ER" version will have to be done manually and although not as easy as the AIO method by following all of the steps in order you achieve pretty much the same results!
The following 2 users liked this post by Westcoast:
718socal (02-02-2023), xterm (02-02-2023)
Old 02-02-2023, 01:08 PM
  #349
718socal
718socal's Avatar
Yes, I just asked @CaneTLOTW and he told me he was gonna check if he made AIO for EU.
xterm (02-02-2023)
Old 02-02-2023, 02:44 PM
  #350
xterm
xterm's Avatar
@Westcoast @718socal
Thanks a lot!
Old 02-02-2023, 06:25 PM
  #351
rennforum
rennforum's Avatar
I am trying to confirm if I need to install GPS antenna for Nav update.
My car is GTS and has factory Carplay and Porsche Connect. Unfortunately I am going over paperwork so dont have car near me yet.
Anyway would like to get what I need ahead of time.
Main goal is to have Trace Precision App so I assume GPS antenna is a must.
Is it possible to confirm if have already GPS / Wifi antenna?
Old 02-02-2023, 06:32 PM
  #352
Lucifer
Lucifer's Avatar
Spyders come with CarPlay
Old 02-02-2023, 06:46 PM
  #353
Z06jerry
Z06jerry's Avatar
When did it become standard on Spyder's? I believe it was optional on '21s, not sure about '22s or '23s
Old 02-02-2023, 06:51 PM
  #354
Lucifer
Lucifer's Avatar
I think it is standard for quite some time now, at least in the past two years
Old 02-02-2023, 07:10 PM
  #355
718socal
718socal's Avatar
I am pretty sure that you have the GPS antenna with CP and PC. Post 132 here to physically check it. If you're running AIO, you can check the antenna after the install. Track Precision will work thru CP wired or wireless. You can run TP from your phone or PCM screen
Old 02-02-2023, 07:11 PM
  #356
718socal
718socal's Avatar
Double post
Old 02-02-2023, 07:12 PM
  #357
rennforum
rennforum's Avatar
tks. appreciate the feedback.
Old 02-02-2023, 07:32 PM
  #358
718socal
718socal's Avatar
Sorry CP wireless only with a Carlink or Ottocast module
Old 02-02-2023, 07:42 PM
  #359
edub
edub's Avatar
I'm wondering this myself, TP doesn't seem to need a GPS antenna. We just confirmed last night with someone. It could use the phone GPS if available. Checking with this person to see if it works without car GPS.
Old 02-02-2023, 07:44 PM
  #360
rennforum
rennforum's Avatar
but I remember reading that iPhone GPS is only 1Hz. do you know the frequency on car GPS?
Quick Reply: OEM Navigation Retrofit DIY
