PIWIS 3 Coding Retrofit and Feature Request
#1111
#1112
#1113
Mike981S (08-12-2024)
#1114
I assume you have a 991 based on your previous posts. This is what the fault means in Fault Finding. Then go to the Kombi Actual Values and identify the fault from Warnungslogger. Last go to Manual Coding make it Inactive. I would still recommend you try to fix the issue before disabling the light especially if it is a safety equipment.
Edit
This is an example for Warning 196 which is PSM In Diagnose
Edit
mredwin25 (08-09-2024)
#1116
He says it's still for sale so you can buy it.
#1118
Edit
Edit
#1121
#1122
My guess is anything emission related can't be altered with PIWIS. Maybe someone can figure out opening the exhaust valves with PIWIS.
#1123
He says he is making PIWIS laptops and can provide as many as you want. Why don't you contact him? He says he has sold them and doesn't have any in stock.
[QUOTE=718socal;19588659]Now I am really confused. Above you said you sold it to him. Now you're saying we can buy it from him.[/QUOTE
#1124
[QUOTE=KEICHAN0418;19589315]He says he is making PIWIS laptops and can provide as many as you want. Why don't you contact him? He says he has sold them and doesn't have any in stock.
Are you selling anything? Maybe make a new thread and advertise there.
#1125
@718socal did you ever do Power Steering Plus coding on PIWIS for anyone? Enabling that feature alone almost paid for my Launch X431 purchase. Its not a huge difference but happy with how it behaves so I'm leaving it enabled. Launch coding below, should be similar for PIWIS...
Electric Power Steering: Coding value--Coding--Servotronic = 1 {Default: Inactive}
Actually loving the white gauges hack even without lit needles, makes the cluster look so much more legible during the day.
Also did you ever find a way to change auto headlight sensitivity - haven't seen anyone report success.
